Author Topic: HRD/DM780 - Macros keep going default  (Read 10552 times)
KK4BFN
« on: March 01, 2014, 01:00:28 PM »
So I am new to the digital world of amateur radio. Set up my equipment, and made a few manual QSO's. I've tried to configure my macros in DM780, but every time I click "OK", they go back to the defaults. I edit them, click ok, then click OK again, but when I get back out to the main DM780 screen, they are back to default again.
I am using the latest free version of HRD, v5.24.0.38, and v5.24.0.38 of DM780....
I don't know what to do at this point.
Kevin - KK4BFN
"No Matter Where You Go, There You Are..."
G0SCX
« Reply #1 on: November 11, 2014, 12:34:24 AM »
Hi There
You can not edit the default set.
Simply go to, say, set 3 - import the default set and there you can edit away to your hearts content.!!
Nice simple system.
Best of luck
W4PC
« Reply #2 on: November 13, 2014, 03:55:27 PM »
the answer is incorrect, this was fixed in 6.x
« Reply #3 on: November 14, 2014, 01:01:27 AM »
The OP is using 5.24
K5UNX
« Reply #4 on: November 14, 2014, 10:01:45 AM »
I had the same problem with 5.24.x . . . I found a file somewhere was set to read-only and I had to change it to read-write. I don't recall which one but i'll try to look for it tonight or tomorrow.
Not trying to be difficult, but I found the answer on google but it took a while and several tries.
N2IIE
« Reply #5 on: November 28, 2014, 07:20:48 PM »
G0SCX is correct. I had the same issue. Go to Set 3 and import the default macros. Edit anything you need and then it will work. Just use this group of macros from now on and edit them anytime you want.
