Author Topic: FT 817/817ND outboard CW filter??  (Read 20968 times)
W1JKA
« on: March 03, 2014, 07:24:50 AM »
Seeking any input/observations from any FT 817 [CW side] owners that use or may have used the less expensive outboard audio type CW filters (NESCAF ,HiPerMite etc..) in lieu of the more expensive W4RT/Collins band pass type on board options.Thanks
« Last Edit: March 03, 2014, 07:35:29 AM by W1JKA » Logged
AF6WL
« Reply #1 on: March 03, 2014, 07:58:27 AM »
If you want to filter because the bands are full of signals - beware that the AGC will be driven by all signals in the  IF bandwidth.
However one trick you can still play is to use IF offset to reduce your bandwidth - push and hold CLAR
Long term - the 500Hz CW filter is worth every penny.
W7ASA
« Reply #2 on: March 03, 2014, 12:47:29 PM »
I have a 300 Hz IF filter in my FT-817.  It makes ALL THE DIFFERENCE in the world for CW.  I highly encourage anyone with an 817 who is a CW operator to consider this as the FIRST option to be installed.  Audio filters are good and have their place. However, IF filtering should be your first choice, because the much narrower band width increases your signal to noise ratio tremendously at IF frequencies while it -of course- reduces interference.  If, after this, you add a good audio filter, you will be a happy brass-pounder indeed!
My Two Cents Worth (please adjust for hyper-inflation.)
>Ray
W7ASA ..._  ._
WA9UAA
« Reply #3 on: March 04, 2014, 08:08:39 AM »
Here is a well regarded outboard CW filter. http://www.4sqrp.com/HiPerMite.php  73, Rob WA9UAA
W1JKA
« Reply #4 on: March 04, 2014, 09:01:04 AM »
Re: WA9UAA
Yes, I know why the HiPerMite is well regarded, I have two which I use on my K1, MFJ and SW Labs QRP rigs. I have built two other more expensive kit filters and with the exception of an Autec QF-1A on my IC-7200 the HiPerMite is best for my ears. Neither myself or a few of my nearby QRP friends own a FT-817 to try any type of these filters out on.Thanks
WB0FDJ
« Reply #5 on: March 04, 2014, 09:07:52 AM »
I own a SCAF-1 by Idiom Press and did experiment a bit with my FT-817. It cleaned up some of the annoying hiss and audio artifacts and for casual operating in the clear it helped. But the 500 Hz is really the way to go for a crowded band.
The SCAF-1 now has a permanent place on my Argonaut 509 which would require surgery to place an IF filter. Makes a real difference when there's nothing else.
WB0FDJ Doc 73
AG6WT
« Reply #6 on: March 04, 2014, 01:11:06 PM »
New FT-817 owner here with a SSB filter, considering getting a CW filter.
If I buy a 500Hz filter, would also using a SCAF-1 help for trying to pull out weaker CW signal, or would it work at cross purposes, adding ringing or a hollow sound?
K0OD
« Reply #7 on: March 05, 2014, 11:30:56 AM »
What's your goal? DXing, contesting, or just ragchewing? There's a lot to be said for keeping a station simple. Fewer gizmos mean fewer RF and connection problems. Extreme selectivity could cause you to miss a station calling off frequency. Your brain can be a pretty good audio filter. Some contesters prefer wider filters. Plus It's not like the bands are that crowded nowadays.
Years ago I contested with a TS-850 years ago equipped with a Kenwood 270 Hz filter. I found that an outboard Timewave DSP-9, even in its 100 Hz bandwidth position, helped very little and I soon discontinued using it.
OTOH, I've  discovered that the old Timewave was of immense benefit to my OHR-100A $150 kit radio that I sometimes use for QRP contesting. The Timewave is back on the operating desk.
To answer your question: The outboard filters I've used don't cause ringing or a hollow sound. But ultra sharp filters can add undesirable fuzziness to high speed CW because high speed CW is wider than slow speed. I own a Flex-5000 which allows the creation of custom brick wall filters. For CW I usually tune in a bandwidth of 250 Hz on the main DX bands during contests. Otherwise 500 Hz is fine.
KU3X
« Reply #8 on: March 11, 2014, 09:26:03 AM »
Save your lunch money, sell you blood or do whatever it takes but there is nothing like a CW filter inside the radio. Audio filters DO NOT narrow the pass band, they
only work with audio. I have two each Datong FL 3 audio filters and I still find them useful. But first you need a filter in the radio. Hunt and pounce, your choice
should be 350 hz or less. Send CQ, then a 400 or 500 hz filter is your choice.
For what you are going to spend for a quality outboard audio filter, you'll come close to what a good mechanical filter will cost.
Barry
www.ku3x.net
RADIOPATEL
« Reply #9 on: September 09, 2017, 05:08:36 AM »
Dear Friends
If I go for 300Hz filter will there be any issue in working satellites. If I go for 500Hz any loss in CW compared to 300Hz filter.Pl explain.
Thanking you in advance.
VU2DCI Dinesh Patel
JS6TMW
« Reply #10 on: September 13, 2017, 06:43:58 PM »
I recently added a 500-Hz filter to my IC-721. I also have a Hi-Per-Mite on another radio that has IF shift. The 500-Hz filter does not come close to the audio filter in being able to pull weak signals out of noise and QRM. Maybe a 250 or 200 Hz filter would.
The effective -6dB bandwidth of the Hi-Per-mite is about 150 Hz.
Steve in Okinawa
« Last Edit: September 13, 2017, 06:46:10 PM by JS6TMW » Logged
KD8IIC
« Reply #11 on: September 14, 2017, 05:34:41 AM »
 I have a 500Hz and a 300Hz i.f. filter in the TR7.
Under normal condx the 300Hz is the way to go and I also add audio filtering if required.
The 300 Hz filter is too narrow for real weak signal work.
The audio filters I use is an old MSC Smart Filter and also a CALF from 3rd Planet.
The CALF is valuable having a noise limiter that takes lightning crashes and "muffles" them.
Very effective, makes it well worth the purchase. Makes it easier to work during regional T storms.
The MSC filter is the final filter before a good set of old mil-spec high impedance fones.
KG6LI
« Reply #12 on: November 21, 2017, 08:09:32 AM »
Like Ray, I run the 300hz filter. It's a great little filter and can really pull signals outta the QRM. The only issue I've had is when talking to a ham who's rig is drifting. He can drift right into the rejection area and not be heard....
73 KG6LI
Mark
VK3YE
« Reply #13 on: November 28, 2017, 10:47:17 PM »
You might enjoy these reviews and demonstrations of audio filters from SOTABeams as used with the FT-817
https://www.youtube.com/watch?v=TrkLxPu0REU
https://www.youtube.com/watch?v=weQSb1aQV6E
https://www.youtube.com/watch?v=KfnEN55hx80
Peter VK3YE
Author of popular $US 5 titles 'Minimum QRP', 'Hand-carried QRP antennas', 'Getting back into Amateur Radio' & '99 things you can do with Amateur Radio'. Ebook and paperback editions.
Visit http://home.alphalink.com.au/~parkerp/vk3yebooks.htm or search titles in Amazon.
