Author Topic: Why srtrong SSB signals that won't tune to intelligibility??  (Read 81656 times)
W8MW
« Reply #15 on: May 13, 2014, 04:28:25 PM »
I like the overload diagnosis best, beating my speculation he was listening to the wrong sideband.  But we haven't heard from the OP in a month.  Will the mystery ever be solved?
73 Mike W8MW
K4PIH
« Reply #16 on: May 21, 2014, 06:59:50 AM »
Probably take some flak for this suggestion, but were they AM?
RENTON481
« Reply #17 on: May 21, 2014, 10:02:17 AM »
   Tnx AER....You're right on the mark with it...I find most every CW and SSB signal can be cleaned up very well by simply cutting back about a quater to a half turn on the RF Gain and turn up the volume to compensate, also the built in attenuators on some rigs will help as well.
I wasn't aware that a ham rig made by Yaesu would have this sort of issue. I thought you only had to use this technique with the less expensive SW radios, where strong SSB can swamp the radio's AGC.
Are many ham rigs set up this way, or just this one Yaesu in particular?
K1DA
« Reply #18 on: May 26, 2014, 09:02:46 AM »
Try another radio and A- B it.
KD8IIC
« Reply #19 on: May 26, 2014, 11:57:56 PM »
  RF Gain and attenuator will clean it up, any rig... Ic-718 here and others including Drake tube and solid state.
KE7TMA
« Reply #20 on: May 28, 2014, 03:35:43 PM »
If the local RF noise level is high or there is too much gain from the antenna then turning down the RF gain can help a lot.  The other night on 80m I was having to engage the attenuator on my KX3 just to suppress background noise to s0-s1.
4X1SO
« Reply #21 on: June 05, 2014, 04:21:11 PM »
I had something like this happen to me last week. A station about 30 miles away from me was pegging my S meter on 20 meter SSB. He was so strong that I could disconnect my antenna and still hear his signal. A little while later I went to 10 meters SSB and could only hear one station on the band, The signal was very distorted. I tried all modes and both sidebands but could not get the signal to clear up. I tried a second radio and still no success. With some close listening I was able to make out the callsign. It was the same as the station on 20 meters that was pegging my S meter. I went back to 20 meters and he was still on 20 loud and clear. I think I was copying spurious harmonics on 10 from the 20 meter transmissions.
K3LRH
« Reply #22 on: June 06, 2014, 10:35:35 AM »
....agree with 4X...do the harmonic math.
AF6AU
« Reply #23 on: June 24, 2014, 12:14:08 PM »
I have found oddities here and there transmitting in the "wrong mode" in the wrong place often. Since I'm in So. Calif., I often hear operators in Mexico that don't give a hoot about what sideband where, they run 40 meters in USB on 7.150-7.180, and then there's guys using export 12-10 meter rigs that will run LSB in the CW area of 10 meters as well. I have heard from US hams that are fluent in Mexican dialect Spanish tell me that some are fishermen off the coast of Baja Calif. A 100 watt SSB rig over the ocean water carries well, so I pick them up at "S" 10 or more even though they are 300 miles away.The operators don't care, and their Gov't has worse issues than the USA with doing anything about it. Maybe someday... ?
So you could be recieving a bogie like that..
JML
AF6AU
W9ALD
« Reply #24 on: September 18, 2014, 08:46:58 PM »
You might want to check the voltage regulation in the receiver.  I have seen strong signals affect the voltage regulation on radios that have a marginal regulator.  The issues are hidden with weak signals and with strong signals they rear their ugly heads.
KC2QYM
« Reply #25 on: October 03, 2014, 08:40:44 AM »
I'm sorry to report that many of you who initially responded also don't understand how to use a receiver.  The correct and first response to the poster was to restrict RF gain and use the attenuator.  This thread would have been over in one or two responses.  Perhaps many of you are new operators so you get a one time pass...some of you should know better.
ZL2MC
« Reply #26 on: February 18, 2015, 11:48:10 PM »
Ditto. People have to learn how to drive the radio. The problem is that an SSB signal doesn't develop an AGC voltage as their is no carrier - it just overloads on voice peaks. Turn down the RF gain, turn up the audio gain, turn the AGC off if you can to prevent 'pumping'. Woks well for CW too. Just like I was taught waay back in the 60's. There's nothing new.
K1DA
« Reply #27 on: February 27, 2015, 10:36:32 AM »
  60s though it may be that doesn't seem to bother S Lines or Drake 4 series.
KR6LH
« Reply #28 on: March 09, 2015, 06:20:54 PM »
I hear the same garbled voice signals on 40 and 80.  I think it is a form of voice encoding that splits the voice band into several sub-bands for transmission, then re-assembles them for reception. I don't know if it's a commercial product or home-brew.
Lee KR6LH
ZL2MC
« Reply #29 on: November 21, 2015, 02:50:42 PM »
Some radios have audio derived AGC when switched to sideband. I haven't played with every radio under the sun so I can only base my comments on those that I have.
