Author Topic: Radio Shack 33-128 Microphone  (Read 3605 times)
W9ATB
« on: April 18, 2014, 04:03:46 AM »
I recently purchased a Radio Shack 33-128 mic to use on my Ten-Tec Omni 7.  Can't get the mic to work with the TT mic adapter.  I can get it to key the radio but it's just a carrier and can't get any modulation.  Purchased an after market 3 pin xlr cable with the 8 pin Yaesu mic adapter and same problem.  Any assistance would be appreciated.
73 W9ATB
K9YLI
« Reply #1 on: April 18, 2014, 07:33:20 AM »
Does the specs on the mic  match the  TT  mic input  impedance.
Did you have to do any wireing to the mic connectors, if so  check your work.
Does the  'adapter'  wireing match the  radio  input. ??
Lots of  unknowns.......
Check the  8 pin yeasu radio  inputs  to  TT inputs.  There is no rule that the wireing is the same from on brand to another.
KB4QAA
« Reply #2 on: April 18, 2014, 10:37:44 AM »
Well it's not a surprise that it doesn't work.  The impedances are grossly mismatched.  While it is generally acceptable to go from lower to higher impedance, this situation is extreme and just won't transfer enough audio power to modulate.  Did you obtain and read the spec sheets for mic and radio?
RS Super Cardiod Mic, XLR balanced, 600 Ohms output
http://www.radioshack.com/product/index.jsp?productId=2997390#tabsetBasic
Ten Tec Omni VII, unbalanced, >10,000 Ohms input, Page 38
http://www.w4ish.net/Manuals/pdf/588_manual_release_2.pdf
You need to provide an impedance matching transformer, or an active device.
Heil Sound sells a transformer, XT-1 which you would need to mount in a box.
http://www.heilsound.com/amateur/products/parts
DX Engineering order:
http://www.dxengineering.com/parts/hls-xt-1?seid=dxese1&gclid=COmhgunG6r0CFUNqOgodCnAALw
Audio Technica makes an inline transformer from 250Ohm - 50,000 Ohm, which may or may not work.
http://www.audio-technica.com/cms/electronics/f4b735b4cabc30ea/index.html
Radio Shack has an XLR to unbalanced adapter/txfmr but no specs.
Shure makes one 300 - 40k Ohm.
http://www.musiciansfriend.com/accessories/shure-a95uf-impedance-matching-transformer
Heil Info on Balanced to Unbalanced mic connections:
http://www.heilsound.com/amateur/tips/129-balanced-to-unbalanced-wiring
« Last Edit: April 18, 2014, 10:43:08 AM by KB4QAA » Logged
KB4QAA
« Reply #3 on: April 18, 2014, 10:52:29 AM »
Possible "Quick and Cheap" solutions:
RS has a general purpose 8:1,000 Ohm audio transformer with a million uses for about $3.  The ratio may be close enough for your needs. Alternatively you may be able to scrounge a similar transformer from an old pocket transistor radios, VCR, Stereo, turn table, boom box, etc.  This would be used to drive the speaker, etc.
RS Catalog #: 273-1380
http://www.radioshack.com/product/index.jsp?productId=2103254&filterName=Type&filterValue=Transformers
-Don't give up. Any microphone can be used with any transmitter, audio system, etc. with the proper matching device and wiring configuration!
Don't be afraid to experiment, you can't blow anything up!
bill
« Last Edit: April 18, 2014, 10:57:07 AM by KB4QAA » Logged
