Author Topic: Calculator for number of hops  (Read 38368 times)
AC7CW
« on: May 04, 2014, 03:19:21 PM »
Any recommendations for a propagation calculator that outputs the number of hops when inputted the takeoff angle? A basic chart for same even?
KI6LZ
« Reply #1 on: May 04, 2014, 03:29:24 PM »
Have to know height of ionosphere to desired location and whether it supports the angles. The height varies all over the globe. Very rough rule is 2000 miles per hop at HF at angles say lower than 40 degrees. Vocap will show the different hops possible. No easy answer to this.
KB4QAA
« Reply #2 on: May 05, 2014, 03:04:08 PM »
HamCAP program from Afreet Software is an overlay that uses the VOACAP engine.
On the 'Chart" display, it will show the Elevation Angle,  number of hops and the relevant ionosphere layer, e.g.  "1F2" or "One Hop via F2 layer" for my selected route from Maryland to Missouri, on 20m, for a selected time and date.
http://www.dxatlas.com/HamCap/
HamCAP is free, and probably the best propagation tool available.   I use it with the IonoProbe monitor (pay) which links with HamCAP and automatically inputs Smoothed Sunspot number (90 day) and Kilo index.  IonoProbe monitor is well worth the small price.
IonoProbe and HamCAP will also interface with Afreet's DX Atlas (pay) program.
HamCAP is not well documented by Afreet, however there are several guides by others on the internet.   Be aware some features are hidden, for unknown reason.
« Last Edit: May 05, 2014, 03:11:59 PM by KB4QAA » Logged
KI6LZ
« Reply #3 on: May 05, 2014, 03:37:19 PM »
Just remember that these programs are predictions and very inaccurate. They do not use real time data ionosounde data from all the worldwide stations.
NO2A
« Reply #4 on: May 10, 2014, 08:29:07 PM »
Do the hops vary by band,or are they the same for all bands?
KI6LZ
« Reply #5 on: May 10, 2014, 09:44:16 PM »
Hops vary by ionosphere layer type, E, F1,F2. From the same layer at a given height they generally tend to be the same if supported at that particular frequency. Some variations will occur versus frequency. Don't expect F layer propagation on 7 Mhz during daytime or any E layer at 14 Mhz. Also possible for more hops to be stronger than less hops at some distances.
This is a difficult topic to discuss due to the many factors and variations involved. Try reading up on some of typical and atypical propagation paths, there are many.
NK7Z
« Reply #6 on: May 11, 2014, 06:24:17 AM »
I have a review of HamCAP, with some interesting overlays showing the HamCap prediction and what PSK reporter showed at that same time...  See: http://nk7z.net/review-of-afreet-software-hamcap/ for the review.  If you click the photos, they will expand.
Dave
For reviews and setups see: http://www.nk7z.net
AC7CW
« Reply #7 on: May 12, 2014, 08:37:41 AM »
HamCap is great. I guess I can extrapolate the number of hops from the SNR? I don't see a way to plot each hop or get the number of same so far...
KB4QAA
« Reply #8 on: May 12, 2014, 07:54:40 PM »
1. Go to 'Settings' overlay, enter your station location, Lat Long
2. Go to 'Map' overlay.  Click cursor on desired target
3. Go to 'Chart overlay'  Put cursor on desire time & band
4. At bottom of page is readouts example:
UTC; Freq; SNR in dB; Elevation Angle; Hops & Layer ex. 3F2 is 3 hops, F2 layer; MUF in Mhz (50% historical, represented by red line *turn on optional display).
« Last Edit: May 12, 2014, 07:57:16 PM by KB4QAA » Logged
AC7CW
« Reply #9 on: May 13, 2014, 06:01:57 PM »
OK, thanks all. Good to go here..
AD0AE
« Reply #10 on: May 17, 2014, 07:18:39 AM »
You may already be satisfied with the answer you've gotten and KI6LZ did a nice job answering the questions.  I think what KI6LZ put forth are the issues.
I want to expand the answer a bit.
To truly get the number of hops on a given path, you would need to use some sort of ray tracing software.  From what I have read there are basically two varieties of ray tracing codes a 3-D code written by Jones and Stephenson and there is a 2-D approximate code written by Coleman[1993,1998].  Either of those are considered to be 'the best' in part because they numerically solve the ray paths through the ionosphere using a Hamiltonian optics formulation (or a Lagrangian approach).  The issue with these methods is that they require a good knowledge of the ionosphere and a very good knowledge of Fortran to actually get them up and running.
 There is a program called PropLab http://hfradio.org/swp_proplab/ which is probably the best for amateur radio operators.  Unfortunately, it looks like it is pretty expensive.   There is also this matlab verison (which you may be able to run on Octave - haven't tried personally)  called Ionort: http://arxiv.org/ftp/arxiv/papers/1202/1202.2079.pdf  I know I downloaded the source code for the latter software off of an FTP site if you look in the pdf above.  I know that Ionort, at least, does solve the Jones Stephenson ray tracing code and the matlab part is basically a nice user 'front end' to the real machinery on the backside of the software.
I hope this helps.
73s,
AD0AE
