Author Topic: FT-8900 Programming Problem  (Read 3532 times)
AB3RY
« on: May 06, 2014, 07:52:24 AM »
I recently acquired an FT-8900 w/ the RTS software from another ham.  After testing that the radio functioned as expected, I did a factory reset.  Then I made up a spreadsheet of memories from my FT-7900 (I have the FTB-7900 software for that) and loaded into the RTS software.  Cloning went smoothly with the meter progressing on the radio in concert with the progress bar on the PC and I got the beep at the end.  All looked good, I restarted the radio, but none of the memories were set.  It still looked fresh from the factory reset.
Am I missing something in the process?
Thanks
K6LCS
« Reply #1 on: May 08, 2014, 08:14:05 AM »
Did you download from the radio FIRST, SAVE that datafile, then import the data to that file? Many programming software packages need you to download from the radio first - THEN perform the programming.
Clint Bradford, K6LCS
http://www.work-sat.com
