Author Topic: Moving TQSL To A New Computer.  (Read 3784 times)
KC9UTM
« on: May 18, 2014, 07:37:12 PM »
I'm in the process of setting up a new dedicated computer for amateur radio. I've transferred all my programs and logs to the new computer. How do I transfer Trusted QSL (TQSL) and my TQSL Certificate to the new computer. I downloaded the TQSL program and sent a certificate request. I'm wondering now if I really want or even need a new certificate. Is there a better way to move TQSL to a new computer?
N0IU
« Reply #1 on: May 19, 2014, 03:58:36 AM »
Helps to get your answer from the source:
http://www.arrl.org/files/file/LoTW%20Instructions/TQSL%202_0%202013/Secodary%20operations/Moving%20LoTW%20to%20Another%20Computer.pdf
KC9UTM
« Reply #2 on: May 19, 2014, 04:33:29 PM »
Today I received my new TQSL certificate. After downloading, everything's fine. Thanks!
KF7CG
« Reply #3 on: May 20, 2014, 10:41:05 AM »
Glad to hear you got your new certificate installed!
Did you back it up as a *p12 file on your computer with a copy on a usb drive or different computer. If you have your *.p12 file around you can generally move computers with ease, at least I have been able and able to run TQSL on morethan one computer with the same certificate.
KF7CG
