Author Topic: How can I install a good earthing point?  (Read 12923 times)
M0SDB
« on: May 21, 2014, 07:22:56 AM »
Hi all
My 'shack' is actually my attic so three stories up.
What is the best way for me to install a good grounding point for my kit?
Thanks all for your help
Danny M6 YDB
Theory is when you know everything but nothing works.
Practice is when everything works but you to not know why.
Quite often these two things happen together; nothing works and you do not know why - Arihato
KD0REQ
« Reply #1 on: May 21, 2014, 09:04:26 AM »
one option is an artificial ground, essentially another tuner placing a counterpoise
http://www.mfjenterprises.com/Product.php?productid=MFJ-931
you could run a nice long #6 wire down the outside to a ground field, too.  probably need some ferrites on it to kill spurious resonances. the artificial ground does not provide a DC ground, and a long ground wire introduces RCL components of its own but is going to be more electrical-code friendly.
the old 1920s "hook a wire to the cold water pipe" trick has drawbacks in these days of plastic pipe, and it is alleged it could make the pipes "bite" if you touched them key-down, too.  not the best solution.
in any event, putting a real solid groud that high up makes you a little more inviting to thunderstorms...
W6UV
« Reply #2 on: May 22, 2014, 06:03:09 PM »
Are you talking about an electrical safety ground or an RF ground?
M0SDB
« Reply #3 on: May 26, 2014, 02:09:04 AM »
A good RF ground is what I'm looking for
K1CJS
« Reply #4 on: May 26, 2014, 07:20:07 AM »
You would be better off with a balanced antenna if you could put one up.  RF grounding from a third floor shack is fraught with problems because of the length above actual ground of the grounding conductor.  It isn't impossible, but it is very problematic when changing bands--the length of the ground conductor may all too easily be right at resonance with a frequency or frequency multiple you're attempting to transmit on.  That is why ground cable are always kept as short as possible--to avoid that possibility.
« Reply #5 on: May 26, 2014, 08:01:05 AM »
What is your antenna situation?
K1DA
« Reply #6 on: May 28, 2014, 03:36:27 PM »
I suggest reading the grounding info published by W8JI which can be accessed simply by Googling his call;.
