Author Topic: problems in downloading wsjt-x or jt-65 to my IC-706  (Read 2999 times)
HS0ZFQ
« on: June 02, 2014, 07:59:24 PM »
Greetings:
     I was not sure where to post this so here I go again.The SFI us tanking pretty fast so I have decided to try out wsjt-x and other modes.Today I tried to download wsjt-x and received the following error message:
     C:\wsjtx\hamlib_amsat.dll
An error occurred while trying to rename a file in the destination directory:
     Move failed code 32
     The process cannot access the file because it is being used by another process.
Click RETRY to try again, Ignore to skip this file ( not recommended ) or abort to cancel installation.
Any help would be highly appreciated.
Yours Truly
HS0ZFQ
Chiangrai, Thailand
K2QB
« Reply #1 on: June 03, 2014, 06:16:07 AM »
Intial thought is that there is another application running that is preventing the install from completing. Make sure there are no other programs running before trying the install. Make sure to close any background programs as well. Also if you have any antivirus progams runing you may need to disable them while doing the install.
Jim K2QB
