Author Topic: rig blaster advantage  (Read 7673 times)
ON3BM
« on: June 08, 2014, 08:14:13 AM »
dear om
i bought a rigblaster advantage and the cable fsk  "58131-1501
i connected the rig blaster in the righ way to a yaesu 1200
set the yaesu to usb/cw
and also connected the rig blaster to the pc
i use the software MRP4064 and put the right parameter (sound card etc)
on the receiving mode no problems
but on the transmitting mode : NOTHING
the ptt from the mic is working
the led on the rig blaster don't blink when
pussing the "send" on the mrp4064 text
what don' i see
thank you for your attention and your hint to show me the way
PA0WV
« Reply #1 on: June 08, 2014, 11:41:16 PM »
May be  you have to switch your transceiver in the RTTY mode (FSK) or DATA/USB mode (PSK) not in USB/CW ?
You have to install drivers for thr rig blaster, did you?
Operator manual has instructions how to do that, and you can download them from the website of West Mountain Radio.
« Last Edit: June 09, 2014, 12:22:17 AM by PA0WV » Logged
ON3BM
« Reply #2 on: June 10, 2014, 05:51:40 AM »
to  do it in the right way
on the mrp4064 remove the Phone plug in ptt when using cw
set in the mrp4064  dtr for cw (disable rts/ptt
stereo audio for cw/fsk jack
 on the radio set cw  for straight keying( not elctronic keyer)
greetings
