Author Topic: TNC Engine For Raspian  (Read 69663 times)
K5MF
« on: July 27, 2014, 11:37:28 AM »
Just getting introduced to the Raspi and Linux.  I am looking, haven't done much research yet, for a software TNC that will run under Raspian.  I am thinking something similar to AGW Packet Engine.  Heck it might even run under Raspian, I don't know.  Anyone have any suggestions in this area?
Tom/AE5QB
K4NYA
« Reply #1 on: July 29, 2014, 07:35:37 AM »
It's not a software TNC, but there's the TNC Pi.
http://tnc-x.com/TNCPi.htm
KB1PVH
« Reply #2 on: July 29, 2014, 06:41:09 PM »
Give Dire Wolf a try. https://home.comcast.net/~wb2osz/site/
Dave-KB1PVH
KC2UGV
« Reply #3 on: August 09, 2014, 06:51:30 PM »
And, as always, the standby:  soundmodem.
KT4WO
« Reply #4 on: March 14, 2015, 12:08:47 PM »
RE: "And, as always, the standby:  soundmodem."
But why?
A few guys have done side by side tests with soundmodem and Direwolf(and a few others)...
Direwolf decodes ~10 to 30% better.... Why waste time with soundmodem??
I'm sure soundmodem was great in its day... but does not have the latest code for the newer equip.
Now if that is all that will run on old equip. ,,thats fine....but a Pi will handle Direwolf.
KB1PVH
« Reply #5 on: March 15, 2015, 07:50:07 PM »
 Dire Wolf and Soundmodem are pretty close to each other as far as decoding goes. AGWPE is the one that seems to be lacking with decoding. I have run all three while listening to packet from the ISS and find AGWPE to be the worst.
Dave-KB1PVH
KB3VWG
« Reply #6 on: March 18, 2015, 10:51:25 AM »
Well, TNCs connect to Linux...but you specifically mentioned a 'TNC Engine.'
Since AGWPE allows other computers to use the TNC via IP, was this one of the features you are looking for?
If you are referring to setting up something like a soundcard TNC, you may wish to look here:
http://www.linux-ax25.org/wiki/Soundmodem
KT4WO
« Reply #7 on: March 21, 2015, 05:12:13 AM »
 Dire Wolf and Soundmodem are pretty close.
If you are talking about the UZ7HO "Soundmodem" ...yes....(but it's windoze only)
The older Linux Soundmodem...No...
KT4WO
KC2UGV
« Reply #8 on: April 20, 2016, 06:03:00 AM »
KT4WO
Which is why you never rely on the distro's supplied version.  Build soundmodem yourself.  Direwolf and newer soundmodem builds are pretty much on part for decoding.
Now, direwolf does lead when it comes to system load, though.  It's a touch lighter on systems, which is critical for embedded devices.
