Just What You Need!
Created by Alan Applegate, K0BG on 2020-04-02
"Editor's Note: Due to the popularity of some of eHam's older articles, many of which you may not have read, the eHam.net team has decided to rerun some of the best articles that we have received since eHam's inception. These articles will be reprinted to add to the quality of eHam's content and in a show of appreciation to the authors of these articles." This article was originally published on: 05/08/2010
Just What You Need!
From time to time, folks ask about hooking up multiple radios to a single speaker. They usually plan on paralleling the outputs together; an obvious faux pas to the informed. Others use a dual voice coil speaker, and that works quite well, unless you need more than two inputs. There is a way, however, and it doesn't require a lot of ancillary hardware to make it all work. You will, on the other hand, need an amplified speaker. One model is available from Radio Shack (part number #21-541). It's powered by a nominal 12 volts DC. The only problem is, it only has one input. There is a simple way to add more inputs, and that's what this article is about.
MFJ makes a similar amplified speaker (MFJ-383). It has a volume control, and a power switch. The Radio Shack unit doesn't have a volume control (one really isn't needed), but it has an automatic power on circuit, so no power switch! Since I already owned a Radio Shack unit, I used it as the test bed. The necessary modifications for the MFJ unit should be identical, but I don't know for sure, as they don't (and won't) supply a schematic for it.
The modification described herein, can be expanded to provide up to 3 additional inputs, although there are diminishing returns. Suffice to say, if you need more than 4 inputs, perhaps you need to rethink your installation. So we know where we're starting from, here is the schematic of the Radio Shack speaker.
The circuitry starting with C1, and continuing to Q1, and beyond, comprise the auto-on feature, and are left intact. All we're going to do, is add two (or three) new transformers (Radio Shack part number 273-1380), and new input jacks (Radio Shack part number 274-251). Incidentally, the 273-1380 transformer's impedance is 8 ohms to 1,000 ohms. The original is slightly higher (≈2,000 ohms), so there will be a slight difference is sensitivity between the inputs. Also note that the speaker jacks float above ground, and this is intentional as some amateur transceivers use double ended audio outputs, just like the KIA6227H audio chip does.
In the case of the Radio Shack speaker, the original audio input jack is mounted on the circuit board. The other inputs can be mounted in the side or rear of the speaker's plastic case. Be careful, however, as the magnet assembly fills the center portion, so the additional jacks should be placed towards the outside edges. The transformers have rather long leads which eases installation. They can be super glued to the inside of the case.
The original 100 ohm R3 should be replaced with a 220 ohm resistor. If you need a little more gain, use a 330 or a 470 ohm resistor. Don't make it any larger, or the auto-on circuit won't work properly. In practice, the audio gain of the attached transceivers is adjusted to give the desired audio level for each one.
The inputs of most medium to high Z, all-in-one chip amplifiers can be easily summed as shown here, as long as you don't need more than 3 or 4 inputs. As alluded to above, if you only need two inputs, a dual voice coil speaker is an easier fix.
Lastly, someone is bound to ask why there isn't step by step instructions, replete with photos? Well sir, somethings just have to be learned the hard way! In other words, hands on.
http://www.k0bg.com
TNNERTPEILE2020-05-08
Just What You Need!
cartier - ure
rolex - ure
Breitling ure
Schweiziske replika Breitling ure , butik, butik , priser , Storbritanien, USA
Breitling
Breitling Bentley Chronograph schweiziske 7750 Herre Automatisk
Brandnavn: Breitling Watch Serie : Breitling Bentley Chronograph Køn: Herre...
DKK 1,997  DKK 1,348
Spar: 33% off
Buy Now
DKK 2,145  DKK 1,446
Spar: 33% off
Buy Now
DKK 1,982  DKK 1,383
Spar: 30% off
Buy Now
DKK 2,018  DKK 1,467
Spar: 27% off
Buy Now
DKK 2,018  DKK 1,369
Spar: 32% off
Buy Now
DKK 1,848  DKK 1,404
Spar: 24% off
Buy Now
DKK 1,863  DKK 1,333
Spar: 28% off
Buy Now
DKK 2,053  DKK 1,411
Spar: 31% off
Buy Now
DKK 1,947  DKK 1,383
Spar: 29% off
Buy Now
Brandnavn: Breitling Watch serie : Breitling Bentley Chronograph køn: Herre...
DKK 1,891  DKK 1,355
Spar: 28% off
Buy Now
Breitling Bentley schweiziske 7750 Herre Automatisk Blå Dial
Mærkevare: Breitling & nbsp; Watch Serie: Breitling Bentley Køn: Herre...
DKK 2,067  DKK 1,383
Spar: 33% off
Buy Now
Breitling Bentley schweiziske 7750 Herre Automatisk Blå Dial rus
DKK 2,018  DKK 1,376
Spar: 32% off
Buy Now
DKK 2,039  DKK 1,369
Spar: 33% off
Buy Now
Breitling Bentley schweiziske 7750 Herre Automatisk Blå Dial Sor
DKK 1,947  DKK 1,453
Spar: 25% off
Buy Now
Breitling Bentley schweiziske 7750 Herre Automatiske Hvid Skive
DKK 1,855  DKK 1,432
Spar: 23% off
Buy Now
kopi hublot ure
kopi cartier - ure
top Breitling schweiziske replika blog
About brightreplicawatches.com blog
Just What You Need!
Herre Barbour Roadster Jakke [6328] - DKK 1,255 : barbour jakke.,prefixWrap:0,src:barbour jacket,relation:[],result:, outletbarbouruk.top US Dollar Euro GB Pound Canadian Dollar Australian Dollar Jappen Yen Norske Krone Swedish Krone Danish Krone CNY
Kategorier
Dame Collection Pige Indsamling drenge Indsamling Mens Collection & nbsp; & nbsp; Herre Barbour AW12 Eksempel & nbsp; & nbsp; Herre Barbour Casual jakker & nbsp; & nbsp; Herre Barbour Fleecejakker & nbsp; & nbsp; Herre Barbour Jacket Liners & nbsp; & nbsp; Herre Barbour Quiltet Jakker & nbsp; & nbsp; Herre Barbour skræddersyede jakker & nbsp; & nbsp; Herre Barbour uldfrakker & nbsp; & nbsp; Herre Barbour vandtætte jakker & nbsp; & nbsp; Herre Barbour Waxed Jakker & nbsp; & nbsp; Herre Internationale jakker & nbsp; & nbsp; Herre Liddesdale quiltet jakker
Featured - [mere]
Dame Barbour Vintage Tweed quiltet jakkeDame Barbour Vintage Tweed quiltet jakkeDKK 1,438 DKK 1,242
Spar: 14% off Dame Barbour Shaped Liddesdale quiltet jakkeDame Barbour Shaped Liddesdale quiltet jakkeDKK 1,392 DKK 1,308
Spar: 6% off Dame Barbour MotoX Jersey JacketDame Barbour MotoX Jersey JacketDKK 1,606 DKK 1,494
Spar: 7% off
hjem","prefixWrap":0,"src":"Home","relation":[],"result":""},{ :: Mens Collection :: & nbsp; & nbsp; Herre Internationale jakker :: Herre Barbour Roadster Jakke .jqzoom{ float:left; position:relative; padding:0px; cursor:pointer; width:301px; height:360px; } Herre Barbour Roadster Jakke Herre Barbour Roadster Jakke DKK 1,319 DKK 1,255
Spar: 5% off
Vælg venligst:
Please Choose
L M S XL XXL
Tilføj til kurven:
Classic Barbour vil aldrig skuffe dig for sin top kvalitet og moderigtigt design . Vælg Barbour herre jakker Herfra kan du nyde vores tung rabat , gratis forsendelse og ingen skat . Tøv ikke med at købe vores nice Barbour jakke !
Herre Barbour Roadster Jacket. Autentiske motorcykel design i polyester med sort Streak Northumberland TJEK foring.
de kategorier","prefixWrap":0,"src":"THE CATEGORIES","relation":[],"result":""},{
oplysninger","prefixWrap":0,"src":"Information","relation":[],"result":""},{
kundeservice","prefixWrap":0,"src":"Customer Service","relation":[],"result":""},{
betaling","prefixWrap":0,"src":"Payment","relation":[],"result":""},{&skibsfart","prefixWrap":0,"src":"Shipping","relation":[],"result":""},{
ophavsret og kopi; 2014","prefixWrap":0,"src":"Copyright © 2014","relation":[],"result":""},{ barbour forretning online","prefixWrap":0,"src":"Barbour Store Online","relation":[],"result":""},{.drevet af","prefixWrap":0,"src":". Powered by","relation":[],"result":""},{ barbour forretning online inc.","prefixWrap":0,"src":"Barbour Store Online,Inc.","relation":[],"result":""
blog
About blog
Just What You Need!
Patek Philippe clearance salg
IWC ure rabat
Rolex-ure på udsalg
Replica Breguet ure, populære Breguet replika ure On Store
Breguet
ure til salg online
Audemars Piguet luksus ure
Breguet ure replika. blog
About watchesreplicaoem.top blog
Just What You Need!
cartier smykker | cartier | cartier watch
Cartier Bamboo Briller
Cartier Bamboo Briller - 001
Cartier Bamboo Briller - 001Cartier er ganske velkendt for sine briller....
DKK 847  DKK 614
Spar: 28% off
Buy Now
Cartier Bamboo Briller - 002
Cartier Bamboo Briller - 002Cartier er ganske velkendt for sine briller....
DKK 1,213  DKK 586
Spar: 52% off
Buy Now
Cartier Bamboo Briller - 004
Cartier Bamboo Briller - 004Cartier er ganske velkendt for sine briller....
DKK 818  DKK 586
Spar: 28% off
Buy Now
Cartier Bamboo Briller - 005
Cartier Bamboo Briller - 005Cartier er ganske velkendt for sine briller....
DKK 1,136  DKK 614
Spar: 46% off
Buy Now
Cartier Bamboo Briller - 006
Cartier Bamboo Briller - 006Cartier er ganske velkendt for sine briller....
DKK 1,009  DKK 607
Spar: 40% off
Buy Now
Cartier Bamboo Briller - 008
Cartier Bamboo Briller - 008Cartier er ganske velkendt for sine briller....
DKK 1,178  DKK 607
Spar: 49% off
Buy Now
Cartier Bamboo Briller - 009
Cartier Bamboo Briller - 009Cartier er ganske velkendt for sine briller....
DKK 1,002  DKK 642
Spar: 36% off
Buy Now
Cartier Bamboo Briller - 010
Cartier Bamboo Briller - 010Cartier er ganske velkendt for sine briller....
DKK 1,418  DKK 621
Spar: 56% off
Buy Now
Cartier Bamboo Briller - 012
Cartier Bamboo Briller - 012Cartier er ganske velkendt for sine briller....
DKK 889  DKK 607
Spar: 32% off
Buy Now
Cartier Bamboo Briller - 013
Cartier Bamboo Briller - 013Cartier er ganske velkendt for sine briller....
DKK 903  DKK 635
Spar: 30% off
Buy Now
Cartier Bamboo Briller - 014
Cartier Bamboo Briller - 014Cartier er ganske velkendt for sine briller....
DKK 1,101  DKK 642
Spar: 42% off
Buy Now
Cartier Bamboo Briller - 015
Cartier Bamboo Briller - 015Cartier er ganske velkendt for sine briller....
DKK 1,150  DKK 628
Spar: 45% off
Buy Now
Cartier Bamboo Briller - 016
Cartier Bamboo Briller - 016Cartier er ganske velkendt for sine briller....
DKK 959  DKK 635
Spar: 34% off
Buy Now
Cartier Bamboo Briller - 019
Cartier Bamboo Briller - 019Cartier er ganske velkendt for sine briller....
DKK 1,319  DKK 593
Spar: 55% off
Buy Now
Cartier Bamboo Briller - 020
Cartier Bamboo Briller - 020Cartier er ganske velkendt for sine briller....
DKK 1,291  DKK 621
Spar: 52% off
Buy Now
Cartier Bamboo Briller - 021
Cartier Bamboo Briller - 021Cartier er ganske velkendt for sine briller....
DKK 762  DKK 593
Spar: 22% off
Buy Now
Cartier Bamboo Briller - 022
Cartier Bamboo Briller - 022Cartier er ganske velkendt for sine briller....
DKK 896  DKK 607
Spar: 32% off
Buy Now
Cartier Bamboo Briller - 023
Cartier Bamboo Briller - 023Cartier er ganske velkendt for sine briller....
DKK 776  DKK 600
Spar: 23% off
Buy Now
Cartier Bamboo Briller - 024
Cartier Bamboo Briller - 024Cartier er ganske velkendt for sine briller....
DKK 1,199  DKK 642
Spar: 46% off
Buy Now
Cartier Bamboo Briller - 025
Cartier Bamboo Briller - 025Cartier er ganske velkendt for sine briller....
DKK 917  DKK 586
Spar: 36% off
Buy Now
Cartier Bamboo Briller - 026
Cartier Bamboo Briller - 026Cartier er ganske velkendt for sine briller....
DKK 1,171  DKK 600
Spar: 49% off
Buy Now
Cartier Bamboo Briller - 027
Cartier Bamboo Briller - 027Cartier er ganske velkendt for sine briller....
DKK 1,340  DKK 600
Spar: 55% off
Buy Now
Cartier Bamboo Briller - 028
Cartier Bamboo Briller - 028Cartier er ganske velkendt for sine briller....
DKK 1,249  DKK 607
Spar: 51% off
Buy Now
Cartier Bamboo Briller -003
Cartier Bamboo Briller -003Cartier er ganske velkendt for sine briller....
DKK 952  DKK 614
Spar: 36% off
Buy Now
billige ure
luksus ure
Briller blog
Briller
About cartierwatches.top blog
Just What You Need!
pandora beads
pandora jewelry
pandora beads
Billige Pandora Outlet udsalg-Pandora charms | Pandora smykker
  1. Pandora Alfabet Perler Letter A Silver
    DKK 339  DKK 169
    Spar: 50% off
  2. CL48094 Standard Size Brun Mønster Pandora Beads Screwed Core
    DKK 261  DKK 155
    Spar: 41% off
  3. CL48115 Standard Size Red Pattern Pandora Beads Screwed Core
    DKK 310  DKK 155
    Spar: 50% off
Nye produkter for november
Pandora Perler Med Sten Fire Diamond Pink
DKK 339  DKK 148
Spar: 56% off
Pandora Perler Med Sten Fire White
DKK 275  DKK 148
Spar: 46% off
Pandora Perler Med Sten Full Diamond Blå
DKK 296  DKK 148
Spar: 50% off
Pandora Perler Med Sten Flower Purple
DKK 332  DKK 148
Spar: 55% off
Pandora Perler Med Sten Full Diamond Silver
DKK 289  DKK 148
Spar: 49% off
cheap pandora number and alphabet charms for sale
pandora number and alphabet jewelry
Pandora smykker engros blog
About pandoraoutlet.cn blog
Just What You Need!
Spyder ski jakker
Spyder ski jakker
jakker blog
jakker
About hothermesbags.com blog
Just What You Need!
første kopi ureiwc ureiwc
iwc portofino indsamling iw510104 mænd er manuel mekaniske ure (iwc) - DKK 1,453 : replika iwc ure , iwcportuguresewatches.top US Dollar Euro GB Pound Canadian Dollar Australian Dollar Jappen Yen Norske Krone Swedish Krone Danish Krone CNY -->
betaling | skibsfart og afkast | engros | Kontakt os Welcome! logge på eller registrere din indkøbsvogn er tom
drevet af Zen Cart:: kunst af E-handel
Home :: iwc ure :: iwc portofino familie :: iwc portofino indsamling iw510104 mænd er manuel mekaniske ure (iwc) .jqzoom{ float:left; position:relative; padding:0px; cursor:pointer; width:301px; height:300px; } iwc portofino indsamling iw510104 mænd er manuel mekaniske ure (iwc) iwc portofino indsamling iw510104 mænd er manuel mekaniske ure (iwc) DKK 28,114 DKK 1,453
Spar: 95% off Tilføj til kurven:
  • Description
Produkt parametre:
  • køn Mand bord
  • bevægelse Manuel mekanisk ur
  • tabel formet Rund
  • urrem krokodille
  • urskive skifer grå
  • tilfælde 0 rose guld
  • pris 100.000 - 15 wan
  • serie portofino familie
  • størrelse 45mm
  • tykkelse 12mm
  • vandtæt 30 meter
  • Bunden af ??tabellen Gennemsigtig
  • fold almindelige
  • tabel spejl dobbeitsidet anti - reflekterende sapphire glas buede kant
  • Graduation Send
  • krone -
  • Strap Color brun
  • Egenskaber Dato Display
iwc [iw510104 Introduktion]
et hundrede 36 år, lokale iwc schaffhausen i det schweiziske watchmaking koncentreret undersøgelse.arbejder for at skabe en tidløse klassiker, dens udformning og teknologi leder i industrien har været iwc giver mange fremragende resultater i kraft.fra iwc er ekstraordinære teknologi og håndværk er ikke blot fremragende schaffhausen, beskrivelse af ren teknologi, men også afspejler iwc har konsekvent fastholdt sit formål.schaffhausen samlet ledende vagt, både præcise tekniske præstationer og udestående design.som ingeniør i urindustrien, iwc sig selv som eksempel fabrik produktion, hvis arbejde og holde sig til urindustrien håndværkstraditioner nedarvet fra generation til generation.
/swisswatches_2016_/IWC-Watches/IWC-Portofino-Family/IWC-Portofino-collection-IW510104-Men-s-manual.jpg
/swisswatches_2016_/IWC-Watches/IWC-Portofino-Family/IWC-Portofino-collection-IW510104-Men-s-manual-1.jpg
/swisswatches_2016_/IWC-Watches/IWC-Portofino-Family/IWC-Portofino-collection-IW510104-Men-s-manual-2.jpg
/swisswatches_2016_/IWC-Watches/IWC-Portofino-Family/IWC-Portofino-collection-IW510104-Men-s-manual-3.jpg
Related Products
iwc portofino indsamling iw391006 mænd er automatisk mekaniske ur (iwc)iwc portofino indsamling iw391006 mænd er automatisk mekaniske ur (iwc) iwc portofino indsamling iw356308 mænd er automatisk mekaniske ur (iwc)iwc portofino indsamling iw356308 mænd er automatisk mekaniske ur (iwc) IWC Portofino samling IW356403 mekaniske kvindelige form (IWC)IWC Portofino samling IW356403 mekaniske kvindelige form (IWC) iwc portofino indsamling iw356501 mænd er automatisk mekaniske ur (iwc)iwc portofino indsamling iw356501 mænd er automatisk mekaniske ur (iwc)
Write Review
IWC ONLINEBUTIKKER billige IWC ure REPLIKA IWC ure IWC PILOT ure IWC SPITFIRE ure IWC DAVINCI ure Copyright © 2012 All Rights Reserved. IWC ure til mænd
IWC ure til salg
watches blog
watches
About iwcportuguresewatches.top blog
Re: Just What You Need!
Herve Leger stikkontakt
Herve Leger
Herve Leger tøj
Grøn V Neck Kate Mara Herve Leger Bandage Dress [Green V Neck Kate Mara Dress] - DKK 1,326 : hervelegercheap, hervelegersales.top
DKK 2,695  DKK 1,326
Spar: 51% off
Vælg venligst:
Tilføj til kurven:
Grøn V Neck Kate Mara Herve Leger Bandage Dress.
Jeg elsker at se en stram kjole på en kvinde, der har flot form . Kate Mara er en ydmyg og sexet ung dame, der næppe fotograferet af paparazzi . Anyways , du bedre nyde disse billeder af hende, fordi du vandt
  • Model: Green V Neck Kate Mara Dress
billige Herve Leger kjoler
bandage kjoler online
Mara blog
Kjoler
About hervelegersales.top blog
Reply to a comment by : TNNERTPEILE on 2020-05-08
[b][url=http://www.pandorajewelry.me/no/pandora-14k-gull-charms-c-4.html]Pandora 1Pandora 14k gull sjarmerer for halskjeder
Pandora 14k gull sjarmerer for armbånd
Pandora Blomster
Pandora Blomster
Pandora Sterling Autumn Bliss Charm T / 83
Hvorfor kjøpe hos oss : 1. 100 % Autentisk Kvalitet . 2. Lett Returrett . 3....
NOK 1,426  NOK 304
Du får 79% avslag
Kjøp nå
Pandora Sterling Edelweiss med gul CZ Charm I / 86
NOK 1,139  NOK 304
Du får 73% avslag
Kjøp nå
Pandora Sterling Forest Trinity med Peridot Charm O / 113
NOK 1,553  NOK 304
Du får 80% avslag
Kjøp nå
Pandora Sterling Hage Odyssey Dangle med Svart Spinell og Grey CZ O / 87
NOK 1,460  NOK 304
Du får 79% avslag
Kjøp nå
Pandora Sterling Mørk Grønn Pave med Mørk grønn CZ Stones Charm J / 117
NOK 1,165  NOK 304
Du får 74% avslag
Kjøp nå
Pandora Sterling Plukke Daisies I / 112
NOK 1,629  NOK 304
Du får 81% avslag
Kjøp nå
Pandora Sterling Red Poppy med Red Emalje T / 109
NOK 1,038  NOK 304
Du får 71% avslag
Kjøp nå
Pandora Sterling Silver Floral Brilliance med Clear CZ Stones H / 118
NOK 1,063  NOK 304
Du får 71% avslag
Kjøp nå
Pandora Sterling Silver My Garden med rød blomst Charm U / 85
NOK 1,401  NOK 304
Du får 78% avslag
Kjøp nå
Pandora Sterling Silver Openwork Wild Flower Walk Y / 84
NOK 1,013  NOK 304
Du får 70% avslag
Kjøp nå
Pandora Sterling Silver Rose Garden med rosa emalje Charm Y / 110
NOK 920  NOK 304
Du får 67% avslag
Kjøp nå
Pandora Sterling Sølv Pink Daisy Charm K / 116
NOK 1,671  NOK 304
Du får 82% avslag
Kjøp nå
Pandora Sterling Sølv Roses Charm P / 114
NOK 920  NOK 304
Du får 67% avslag
Kjøp nå
Pandora Sterling Sølv Shimmering Blossom med Clear , svart og rosa CZ Charm R / 82
NOK 1,165  NOK 304
Du får 74% avslag
Kjøp nå
Pandora Sølv Flower Charm med Dangle White Pearl L / 115
NOK 1,629  NOK 304
Du får 81% avslag
Kjøp nå
Pandora Sølv Perlene med Dangle Grønn Firkløver U / 111
NOK 1,038  NOK 304
Du får 71% avslag
Kjøp nå
Blomster blog
Blomster
About pandorajewelry.me blog
Reply to a comment by : TNNERTPEILE on 2020-04-07
*REMOVED*
*REMOVED*
Pandora Blomster
Pandora Blomster
NOK 1,426  NOK 304
Du får 79% avslag
Kjøp nå
NOK 1,139  NOK 304
Du får 73% avslag
Kjøp nå
NOK 1,553  NOK 304
Du får 80% avslag
Kjøp nå
NOK 1,460  NOK 304
Du får 79% avslag
Kjøp nå
NOK 1,165  NOK 304
Du får 74% avslag
Kjøp nå
NOK 1,629  NOK 304
Du får 81% avslag
Kjøp nå
NOK 1,038  NOK 304
Du får 71% avslag
Kjøp nå
NOK 1,063  NOK 304
Du får 71% avslag
Kjøp nå
NOK 1,401  NOK 304
Du får 78% avslag
Kjøp nå
NOK 1,013  NOK 304
Du får 70% avslag
Kjøp nå
NOK 920  NOK 304
Du får 67% avslag
Kjøp nå
NOK 1,671  NOK 304
Du får 82% avslag
Kjøp nå
NOK 920  NOK 304
Du får 67% avslag
Kjøp nå
NOK 1,165  NOK 304
Du får 74% avslag
Kjøp nå
NOK 1,629  NOK 304
Du får 81% avslag
Kjøp nå
NOK 1,038  NOK 304
Du får 71% avslag
Kjøp nå
Blomster blog
Blomster
*REMOVED*
*REMOVED*
Pandora Blomster
Pandora Blomster
NOK 1,426  NOK 304
Du får 79% avslag
Kjøp nå
NOK 1,139  NOK 304
Du får 73% avslag
Kjøp nå
NOK 1,553  NOK 304
Du får 80% avslag
Kjøp nå
NOK 1,460  NOK 304
Du får 79% avslag
Kjøp nå
NOK 1,165  NOK 304
Du får 74% avslag
Kjøp nå
NOK 1,629  NOK 304
Du får 81% avslag
Kjøp nå
NOK 1,038  NOK 304
Du får 71% avslag
Kjøp nå
NOK 1,063  NOK 304
Du får 71% avslag
Kjøp nå
NOK 1,401  NOK 304
Du får 78% avslag
Kjøp nå
NOK 1,013  NOK 304
Du får 70% avslag
Kjøp nå
NOK 920  NOK 304
Du får 67% avslag
Kjøp nå
NOK 1,671  NOK 304
Du får 82% avslag
Kjøp nå
NOK 920  NOK 304
Du får 67% avslag
Kjøp nå
NOK 1,165  NOK 304
Du får 74% avslag
Kjøp nå
NOK 1,629  NOK 304
Du får 81% avslag
Kjøp nå
NOK 1,038  NOK 304
Du får 71% avslag
Kjøp nå
Blomster blog
Blomster
*REMOVED*
*REMOVED*
TNNERTPEILE2020-04-07
*REMOVED*
*REMOVED*
Just What You Need!
*REMOVED*
N3HAT2020-04-04
Just What You Need!
A few nits:
1. The supplemental schematic says "to the junction of C1 and R1". Shirley you meant C1 and R3, since C1 and R1 do not connect in the original circuit.
2. The original drawing shows a 100 ohm load resistor on the secondary of the input transformer. When reflected through the 8 ohm:2K ohm transformer, this means that the transceiver driving the unit sees 0.4 ohms (plus the resistance of the connecting cable) -- practically a short circuit. Your transceiver's audio output stage is probably rated to drive a 4- or 8-ohm speaker load -- nothing less. Driving a short risks damage to the transceiver. At the least, overheating and distorted audio are possible. (Are you sure that the original input transformer is 8 ohm:2K? If it has a different impedance ratio, say 1:1, then this issue goes away.)
3. Adding inputs by directly parallelling the secondary windings of additional input transformers is not a good idea. Each transceiver will see the output stage(s) of the other transceiver(s) in parallel with it -- again, probably close to a short circuit, with current limited only by the internal resistance of the cabling and transformer windings. When wired this way, the only benefit of the transformers is to prevent ground loops and damage from grounding an output stage that must float. AC-wise, the transceivers' outputs are still overloaded.
What to do? I would isolate the transformers' secondary windings (including the original one) by inserting a 1K series resistor between the hot side of each secondary and the summing node (the junction of C1, R2, and R3) so that the transceiver sees an 8 ohm load no matter how many other transceivers are connected.
Bob N3HAT
KJ4DGE2020-04-02
Just What You Need!
Nice explanation and good info. I can see the practicality of one speaker and a few extra inputs (desk space). I had on of those RS speakers once, it was NICE!
