"Editor's Note: Due to the popularity of some of eHam's older articles, many of which you may not have read, the eHam.net team has decided to rerun some of the best articles that we have received since eHam's inception. These articles will be reprinted to add to the quality of eHam's content and in a show of appreciation to the authors of these articles." This article was originally published on: 12/08/2010
The previous article, Degrees of Antenna Occupied by a Loading Coil, showed how The Hamwaves Inductance Calculator can be used to determine the parameters of an 80m mobile loading coil. Note that the accuracy of the inductance calculator is thought to be 10%. The specifications for the 80m mobile loading coil are:
The above graphic shows how the parameters were entered into the inductance calculator and the following outputs were obtained.
In the previous article, we converted the Axial Propagation Factor to degrees/inch by multiplying by 1.4553 and then multiplied by the 10 inch length of the coil to obtain the number of electrical degrees occupied by the loading coil at 3.5 MHz. We also calculated the Velocity Factor of the coil at 4% of the speed of light in free space. Knowing the VF of the 10 inch coil allowed us to calculate the RF propagation time through the coil.
EZNEC was used to estimate the length of the whip above the coil in order to resonate the mobile antenna on 3.5 MHz. That length is 8.83 feet. So the 3.5 MHz base-loaded mobile antenna consists of the specified 10 inch coil at the base with a whip length of 8.83 feet. It is interesting to note that the reactance of the coil is j2168 ohms while EZNEC says the impedance looking into the 8.83 foot whip is 0.4-j2187 ohms which is in reasonable agreement.
One wavelength at 3.5 MHz is 281 feet so we can estimate that the whip occupies 8.83/281 = 0.0314 wavelength. We can calculate that the loading coil occupies 26.37/360 = 0.0733 wavelength.
The coil occupies 0.0733 wavelengths (26.4 degrees). The whip occupies 0.0314 wavelength (11.3 degrees). That adds up to 0.1047 wavelengths = 37.7 degrees. We know that the resonant mobile antenna is 0.25 wavelength (90 degrees) long. Where are the missing 52.3 degrees?
When we represent the mobile antenna on one half of a Smith Chart, the "missing" degrees are revealed. The 0.0733 wavelength occupied by the coil is plotted "toward the load" with the low impedance feedpoint on the left. The 0.0314 wavelength occupied by the whip is plotted "toward the source" with the high impedance open end on the right. We can now calculate where those "missing" 52.3 degrees come from.
The above image can be viewed in a larger format at: Smith Chart: 3.5 MHz Mobile Antenna The impedance at the coil to whip junction can be obtained by reading the approximately -j0.5 value from the Smith Chart at the top of the coil and multiplying by the characteristic impedance of the coil where Z0 = 4747 ohms.
Note: There is a very small (less than one ohm) radiation resistance of the whip which can be ignored for the purpose of finding the "missing" degrees in this mobile antenna.
Knowing the impedance at the coil/whip junction allows us to calculate the characteristic impedance (Z0) of the whip. The normalized value from the Smith Chart on the whip end is approximately -j5.0 which we know from the above calculation is -j2374 ohms. Therefore, the Z0 of the whip at the coil/whip junction is 2374/5 = ~475 ohms which is a reasonable value.
We can now conclude that the "missing" 52.3 degrees is caused by the impedance discontinuity at the coil/whip junction, i.e. where the Z0 changes from 4747 ohms to 475 ohms. The same thing happens when two transmission lines are connected together if they have different characteristic impedances, i.e. different Z0s.
In a base-loaded mobile antenna, there are three components that contribute to the 90 electrical degrees required for resonance.
1. The coil contributes a certain number of degrees, 26.4 degrees in the above example.
2. The impedance discontinuity at the coil to whip junction point contributes a certain number of degrees, 52.3 degrees in the above example.
3. The whip contributes a certain number of degrees, 11.3 degrees in the above example.
Thus a base-loaded mobile antenna can be analyzed in the same manner that Dual-Z0 Shortened Stubs can be analyzed. The following dual-Z0 1/4WL stub analysis is virtually identical to the above base-loaded mobile antenna analysis. Note that the phase shift at the impedance discontinuity is proportional to the ratio Z0H/Z0L and 4747/475 = 500/50.
Having a bottom section under the loading coil (center-loading) complicates the analysis by introducing an additional negative phase shift at the bottom section to coil impedance discontinuity where the Z0 changes from the low Z0 value of the bottom section to the high Z0 value of the coil. Because the phase shift at the bottom of a center loading coil is negative, the inductance of the coil must be increased to add to the degrees occupied by the coil, in order to compensate for the number of degrees lost by the negative phase shift. That's why, for the same overall antenna length, the center loading coil must have more inductance, i.e. must occupy more degrees of antenna, than a base loading coil configuration.
W5DXP will follow up on center-loaded mobile antennas with a short future article. The primary concepts concerning degrees occupied by a loading coil are covered in this present article.
| W9YW | 2019-11-04 | |
| 80-Meter Base-Loaded Mobile Antenna | ||
| The author's citation above, http://www.w5dxp.com/loadcoil.htm is worth investigating for those interested in a step-by-step analysis. Well done. | ||
