Cold Temperature Testing Your Rigs
Created by Paul Signorelli, W0RW on 2021-02-20
“Cold Temperature Testing Your Rigs” Rev. B By   W0RW
When you are going to be out in the field for Winter Field Day  (WFD), FYBO (Brrrr), or Polar Bear (Grrrrr) operations you want to make sure your rig is still going to work in those cold environments.   You don't want to travel out to some freezing wilderness to find your rig won't transmit or have to wait for the power to come back on in your shack to make sure your rig still works.
This Cold Testing qualification test is a slow Thermal Cold Soak, not a Thermal Shock test.
(Thermal Shock can crack solder joints, you don't want to do that).
At the start of this test I measured and recorded the room temperature characteristics of my radios prior to the test. Measuring RF Power output, Frequency accuracy, keying (chirp), receiver sensitivity, battery voltage and Voltage drop during transmit, etc.
Then I waited for one of those cold winter nights. I put the rigs in my car overnight for the cold soak. Some of my rigs have Commercial parts in them, and some have Military temperature range parts in them that are good down to -30F.
I tested the "1 Watter" 1W20 < http://www.kitsandparts.com/1watter-V3.php> first, It is refitted into an old military radio chassis.
It passed - 6F.
It is nice to have a rig that has big knobs for gloved operation in cold temperatures.
Some radios have small switches that are hard to get at with gloves on but once set, gloves can still be used.
Then I put my PRC64, PRC74, PRC319, and  Elecraft KX1, outside for an overnight cold soak at -10F. The next morning I re-measured all the characteristics and looked for LCD display errors on the PRC319. They all passed. The test did spot some limiting accessory issues: Some cables were not mil spec and bending them could crack the insulation, Some controls got very hard to turn, One commercial switching power supply would not start, Some batteries were not as good as I had thought they would be, 50% lower capacity.
Then I brought the radios back up to +60F in a low humidity room with the power removed to prevent dendrite growth, (See https://www.eham.net/article/38606).
You don't want the radios powered on as they go through the dew point.
You should not do this kind of testing using your home freezer because that could cause Thermo Shock damage.  I wouldn't recommend any Thermo Shock (Quick Freeze) testing unless you are prepared to fix your radio.
Now all the radios are qualified I am ready to go.
Some have asked "What about the operator"? Well when it gets really cold I use my WW2 US Army Air Force 'F-1' Heated Bunny Suit that was used in B25's, etc. See Photo.
It is like an electric blanket but in a zippered jump suit style. It runs on a 12V battery.   Heated Motorcycle apparel is also available.
This is my active cold weather gear.
I also use a ‘Key Muff’ made out of an old rug for my CW paddle, See Photo.
In the picture of me at St. Elmo Ghost Town, CO, in 2 feet of snow using the PRC319 shows that I have wool half gloves on for sending CW.
Paul, W0RW
Snowy Colorado
W0RW2021-03-01
Re: Cold Temperature Testing Your Rigs
Yes the ice sickle was going to give me a better grounding point but it broke off. i was feeling like Thor throwing down Thunder Bolts of ice sickles on to the earth.
St. Elmo has lots of 'St Elmo's Fire' at 11,000 feet.
It is just below the Continental Divide. It is one of the greatest Ghost Towns in Colorado.
My vehicle was an old 1982 Subaru w/ 4 wheel drive.
Google 'St. Elmo Colorado', You have to visit there.
Paul w0rw
Reply to a comment by : KC6RWI on 2021-02-28
WORW, wow, you got all the good stuff, the suit, the back pack rigs, now don't tell me you have a vintage dodge power wagon to get the mountains.
Reply to a comment by : VE7KKQ on 2021-02-28
Is tat a "Grounding point" you're hanging on to?
KC6RWI2021-02-28
VE7KKQ2021-02-28
