MFJ-986 Antenna Tuner
Created by on 2021-09-10
In 2019 I purchased a brand new MFJ 986 antenna tuner. When I received it and as I was removing from the box, and you could hear a part rolling around in it and then inside the shipping box there was a one-inch bolt. I called them and they sent me another one and it worked great for a year.
Then a year later it started to act erratic, so I opened it up and it was full of metal screw particles. I took a brush and compressed air and cleaned it out.
Next, I took a can of DeoxIT D-Series D5 electronic cleaner and sprayed all the connections, also the two gears for the Inductance knob were out of aligned so I corrected them also. Boy what a difference all around now. I am very happy with this tuner again and it even adjust a LOT smoother now.
Hopefully this will help others who may be having this problem!
VE3CUI2021-09-12
I'm not intimately acquainted with the MFJ-986 tuner, but if it has a roller inductor in it, try this trick that veteran General Motors toolroom techs used to use on all of their electro-mechanical devices to ensure smooth, trouble-free operation: apply just a couple of dabs of ordinary CASTOR OIL onto those components that a contact roller(s) might slide across as the inductance is varied.
PERIOD.
I do this on my home-brew transmatch, as well as my home-brew linear amplifier --- both of which employ large air variable inductors --- & the result is smooth-as-silk reliable operation, for years.
I also apply just a dab of castor oil onto the bearings of variable capacitors here, as well --- gets rid of any stickiness, yet does not affect-alter the capacitance in any adverse way.
Just REMEMBER, though: "A LITTLE DAB'LL DO YA...!!!"
