This is what Ham radio is about, sharing experiences and knowledge to advance the art. After developing a way to rotate my hexbeam antenna remotely 200 miles away from the shack using a WIFI IR hub with a RCA VH226E antenna rotator I knew I would need to figure out how to connect and disconnect my antenna remotely 200 miles away. Have you ever been out of the shack running an errand when a thunderstorm comes up and you forgot to disconnect your antenna? I came up with a solution after giving it a lot of thought on how to remotely disconnect or connect my antenna from my Smartphone using WIFI. I purchased the items below and assembled them in one afternoon. Most parts can be purchased online from eBay and Amazon. I have attached a PDF file that is complete in details.
To assemble:
I am sure this prototype could be built cheaper and maybe better. I pulled parts from my spares box and bought what I needed to make the WACDS. There is a parts list at the end with prices, these may vary. I don’t have a metal or wood shop to work in to build stuff. I just built this in my home office in about 3 hours or so. It was fun.
Price | Description |
$39.99 | Linear Actuator |
$10.79 | H shape actuator bracket |
$20.99 | WIFI Controller |
$9.79 | Power Supply |
$17.99 | Power Distribution blocks |
$16.89 | Push on PL259 Male |
$10.35 | PL259 Male to Male |
$8.90 | SO-239 Female Adapter Thru Barrels |
$106.99 | Polyphaser Surge Protector or equivalent. |
$29.00 | Polyphaser L bracket BF-Adapter or equivalent. |
$8.48 | Project Mounting Board |
$5.98 | Wood Screws Assortment Pack |
$7.98 | 20 guage wire |
$3.99 | Cable Ties |
$15.91 | Cable clip/holder |
$8.99 | L brackets |
$5.27 | Velcro Strips |
$314.02 | Total cost. |
Tools needed: Phillips and Flat Blade screwdrivers. Drill & bits. Wire cutter, stripper, and crimper. |
See attached PDF file for easier reading.
Kc4zze WIFI Antenna Connect-Disconnect System
K5TED | 2023-09-20 | |
KC4ZZE Wi-Fi Antenna Connect-Disconnect System | ||
IMO this is a great idea. I lost a $3600 shack back in the late 80's (a lot of money then) from this exact thing happening. I went to work on a sunny day. By 3pm my shack was destroyed. I came home to the smell of burnt electronics. I think the main issue is the actual physical isolation of the antenna and coax. Antenna switches commonly put the unused connections to ground. What if the lightning comes right down the shield to the shack to house ground to utility ground lug through the rig chassis? I've seen a machined aluminum amplifier case end up in a football shape with all the guts black from just a tiny black mark on the 2m J-Pole it was connected to. Death, destruction. Your idea of a relatively large physical separation is good. |
