DX Antennas: Verticals vs. Horizontal:
from Bob Raynor, N4JTE on November 24, 2013
By N4JTE
After reading many comments endorsing vertical antennas as the best choice for lower band DX, I decided to do some real world evaluation and documentation from my backyard in the Hudson Valley of NY. on 40 and 80 meters. Elevation is 382ft. asl with Shawgunk mountains East and Catskill mountains North .
Not my first QTH choice for DX chasing!
All antennas basically favor East/ West.
THE ANTENNAS
80 Meters
A: Phased 2 element verticals using #12 insulated wire on 60ft. Spider Poles with 1/4wl spacing using Christman phasing. Each vertical had four non symmetric raised radials at approximately 6ft. high and 60ft. long. The impedance was measured at 30 ohms for each vertical. The SWR was 2 to1 and fed direct. B: 2 element dipoles at same poles using 20 gauge insulated wire at 55ft. tall. Dipoles were somewhat flat with non-symmetrical ends due to tree locations, not ideal spacing and some ends dangling. SWR was 2.2 to 1 and fed direct.
40 Meters A: Phased 2 element verticals at 50ft. tall with four raised radials angling down from 12ft. Same phasing 1/4wl spacing with 50 ohm impedance, fed direct. B: Phased 2 element horizontal dipoles, above photo, at 40ft. high at 1/4wl spacing resulting in SWR of 2.1 to1.
NOTES
∑ The antennas were tested with the usual antenna 1, antenna 2 query, no description was provided until after reports were exchanged.
∑ Switched at desk with less than one second comparison delay.
∑ During 80 testing the 40 antennas were disconnected with radials on the ground. Same was done during 40 testing to alleviate possible mutual coupling. Some late night flashlight work involved with that, hi.
∑ ALL antennas were reversible and exhibited very substantial gain and front to back but those results were not included for clarity on the chart.
∑ Most contacts available for review on DX Summit under my call.
∑ Stateside not charted as we are discussing DX, but worked 91 stations as OMISS 40 NCS one night, awhile back. The verticals never exceeded the horizontal with HI, AK and 38 other states in the mix.
CONCLUSIONS:
Pretty obvious from my backyard that the horizontal wires outperformed the verticals almost 100% during the tests. It may appear as a small sample as presented, but I only presented verifiable contacts as posted on DX summit. There were uncounted multitudes that put up with this experiment and I thank all of you for letting me butt into qsoís on 40 and 80.
I have heard some very strong signals from vertical antennas on the bands. They are an antenna that truly depends on location, location, and Installation!
As far as being a better DX antenna, some or all the time; I donít see that from here! I compared well-constructed vertical and horizontal wire gain antennas in the same direction and I feel it was a very fair test. This experiment was informative to me and resulted in my removing all vertical wires and radials and stay exclusive to horizontal phase reversible wires for 40 and 80 DX.
Your mileage may vary!
Tnx for reading,
by W1JKA on November 24, 2013 Mail this to a friend!
Nice article,Once again you have shown the value of A/B comps and the effects of QTH, ground conditions and installation. Only those of us that have done this will know for sure and those who have not are either unable to for various reasons or refuse to admit that they will never know.
In defense of the vertical antenna
by AI2IA on November 24, 2013 Mail this to a friend!
Note the following words in the article:
" I compared well-constructed vertical and horizontal wire gain antennas in the same direction and I feel it was a very fair test."
Yes, IN THE SAME DIRECTION he felt that it was a very fair test.
Hams cannot easily rotate wire dipoles. This is an understatement at best.
For the ham who has limited space, as most do, the vertical antenna offers the possibilities of DX. Also, since most vertical antenna arrangements for the average ham are OMNIDIRECTIONAL, he does not miss incoming signals from off the weak ends of a fixed position wire dipole.
More could be said in comparison regarding other features, but for now a well constructed and thoughtfully placed vertical antenna can be a very satisfactory choice for many hams. I leave other advantages to further commentators.
by WA1RNE on November 24, 2013 Mail this to a friend!
Bob,
A question and a suggestion:
Are the 80 meter dipoles located directly above the verticals as depicted in your drawing with the dipole feedlines running along the vertical radiator?
I noticed the feedpoints of the 80 meter verticals are 12 feet above ground while the 40 meter verticals are at 6 feet. This is actually the opposite of what you want to do - you will see higher efficiency by virtue of lower ground losses on 80 with the feedpoint at 12' or close to 0.05 wavelength over ground. This is based upon my own experiences as well as the findings by others, such as VK1BRH in his 1995 paper "Short Vertical Antennas and Ground Systems- VK1BRH"
Efficiency will also be improved by matching the feedline to the 30 ohm feedpoint impedance. This is pretty easy to do with a simple L network or a T network.
WA1RNE
by NB5N on November 24, 2013 Mail this to a friend!
Nice article, Bob. Pretty convincing, but too many variables to be definitive for all installations. Have you considered testing individual antennae rather than phased? Also, I'd like to see a similar comparison including a G5RV and an OCF windom. That may help address the omnidirectional vs directional differences somewhat. Keep up the good word. Thanks for sharing. 73
RE: DX Antennas: Verticals vs. Horizontal:
by KC7MF on November 24, 2013 Mail this to a friend!
I agree with AI2IA. The casual reader should note that these vertical antennas the OP is testing would not reflect the performance of an omnidirectional vertical antenna. These antennas are neither stealthy nor do they fit within a small footprint; both features many vertical antenna fans admire.
I find my vertical antenna ideal for casual DX given that I have to consider space and stealth. Its omnidirectional nature is ideal for the one-antenna solution many of us need.
by JOHNZ on November 24, 2013 Mail this to a friend!
I have run many tests similar to this over the years for my employers. Some tests were under laboratory conditions, the rest under various field conditions around the world. Some of my concerns with your test results are your small sample, your location, and lack of sufficient supporting information. I believe these, and a few other things, have led you to produce less than accurate results, leading to insufficiently supported opinions. The ionosphere skews most polarized signals most of the time, producing a mixed collection of signals, which is yet another important consideration. When a ham asks me for my opinion, I normally first state, "It all depends." (Note, I never give a definitive reply.) Some considerations are that it depends on what you are mostly going to use your ham equipment for and what your limitations are? Can you maintain what you erect? For the ham with limited resources, it is still nice to have two antennas, one for short skip and one for DX and a switch to utilize both antennas. On the other end of the scale, I have a college buddy, who is well known on the DX cluster. His retirement home sits on 65 acres of land, and it is covered with every imaginable antenna. His problem is too many antenna choices, a problem many of us would like to have.
by G3RZP on November 24, 2013 Mail this to a friend!
On one occasion, my 40m full wave centre fed dipole at 60 feet running SE-NW gave a better report by about 1 S point from VK2 on 40m. But for receiving, my sloper pointing SW did better by about 1 S point.....
On 80 and 160, my folded vertical with no radials beats the horizontal for DX outside Europe every time. DX like Heard Island on 160m....
YMMV...........
by N4JTE on November 24, 2013 Mail this to a friend!
To answer some points;
80 verticals were fed at ground point with raised radials angled up as drawn.The 80 dipoles were on same pole with the phased lines connected at top and running off about 60 degree angle to the mid point relay /feedpoint resulting in little or no coupling as they were at around 30 feet away from verticals on the poles.
The 40 verticals were constructed on another pole at 50 ft and a tree 33ft away with raised radials angled down and tied off.
If dx antennas are to be compared it makes sense to compare both antennas with the dx station which is obviously in the same direction.
If I was forced to choose due to space I would definetly try to get a dipole or inverted vee installed rather than a vertical.
The article was a backyard experiment and as such is not intended to be a scientific paper nor definitive proof, just my observations and conclusions.
As said, your milage may vary.
N4JTE
by LEON on November 24, 2013 Mail this to a friend!
Nice article Bob. Thank you for putting all that together.
I agree that their are folks that comment and endorse many different antennas for best DX or whatever else. It usually starts with money. The makers and designers of anything stand to make money if they can sell a product. It doesn't have to be the best, they just have to make us think it is so we will buy it.
Mosley is the best, just ask them.
Gap is the best, just ask them and read the reviews they have put on their Site.
The Carolina Windom is the best, just ask anyone who sells them.
Zero Five is the best vertical ever made, just ask the person who sells it.
The DX Blaster is a flame throwing Caged Dipole that cannot be beaten, just go on their website and you may want to buy one. They sell it very well.
Radio Works sells wire and wire antennas, plus a bunch of other stuff. They also sell it very well.
Bob, you spoke about how it was pretty obvious from YOUR backyard and location, location, location.
I agree with that, YOUR backyard and mine may be different. I think you can TRY to put all of this in a nice box but in reality you can't.
Thanks for a cool article Bob, it made me think!!
LEON
by KE6SLS on November 25, 2013 Mail this to a friend!
Thank you for your observations on these antennas Bob.
One thing of note on your chart is the lack of qso station polarization. I would have made that a big part of my compiled stats.
I agree that a good omni vertical is a great antenna, esp if the op builds the very best radial system they can. And I also LOVE my simple inverted dipoles with balanced feeders. I don't use coax here, and don't care about resonant antennas.
If I had some room, however, I would sure love to build some phased verticals and dipoles! Gosh that would be a lot of fun!
Thanks again om, keep up the good work!
j
by N4UFO on November 25, 2013 Mail this to a friend!
Vertical vs horizontal for the average ham is completely a site by site determination... While I am not well versed enough to give the properly detailed explanation, I do know that the ground conditions for miles around the site have a lot to do with whether or not the average vertical installation will be a good DX antenna AT THAT LOCATION. If the ground is not appropriate, you will not see the low angle radiation that makes a vertical antenna laudable. It has to do with ground slope, soil content and obstructions. (Because with out the low angle radiation, it's no better than a bent dipole sitting on the ground...) And since a vertical is highly dependent on ground return currents for proper efficiency, your elevated radial arrangement is also a highly suspect factor. I tried elevated radials.... then I laid down 3000' of wire for three verticals. So far I am finding 32 'on ground' radials to be much better.
What I will say is this... Get on 160 meters and trying working much DX with a dipole. Don't have 120 foot tall supports? You'll discover the value of a vertical real quick. I just can't imagine why all the biggest DXers & contesters would invest thousands and thousands in full size verticals and four square arrays if they could do better with a dipole... Look up WD5COV on QRZ and see his antennas... that's a lot of money invested to be so wrong. I think he might know something we don't... ;^D
73, N4UFO
N4JTE, I just looked at your QRZ page... did you try out those experiments in THAT back yard? With all those two story buildings that close all around??? And also mountains in the near distance?!!! PFFFT!!! No WONDER! That's simply NOT a fair comparison AT ALL. OF COURSE if you put a vertical down in a bowl, it will do WORSE than a dipole sitting ABOVE the bowl!
Please understand, I am not trying to rip you or start an argument, but you apparently started out with an agenda to disprove the idea that verticals are not as good as horizontal antennas... I will concede that point, PROVIDED that you accept the caveat/disclaimer... NOT IN YOUR BACK YARD.
To do otherwise is to be intellectually disingenuous and frankly downright absurd. Go move to a flat open piece of property somewhere and try the experiment again... you might change your mind. X^(
OKAY, OKAY... before the flames start... I re-read the article. Bob, you do say:
"They are an antenna that truly depends on location, location, and Installation!"
If I could edit my last couple posts, I would... my apologies. I read the article with a different tone now. I thought you started out to slam verticals... you now appear to be simply saying, 'Not in all cases'. And with that we completely agree. So good on you for experimenting and learning and again, apologies for any offense. I gotta remember to read, read and read again before posting.
73, Kevin N4UFO
by WA8JXM on November 25, 2013 Mail this to a friend!
Valid point about comparing a vertical beam antenna to directional horizontal beam. Were the gains equivalent and in the same direction?
Of course, there is the cost issue for some of us: Four 60' tall supports for phased wire beam antennas is more expensive and complex than a simple vertical. Of course if you are fortunate enough to have big trees growing in the proper spot, that helps.
And then there is the ground plane issue: I doubt that a couple of radials 6 or 10' high is the optimum ground plane for 80 or 40m.
When comparing transmitted signals, what affect does a 2+:1 SWR (on the verticals) have compared to a 1:1 match on the horizontal beam? Some rigs will start cutting power with an SWR like that.
by K5OX on November 25, 2013 Mail this to a friend!
I don't think it is horizontal vs. vertical. Chances are your QTH has a set of angles of radiation that minimize lossy hops over land. The antenna that comes closest to ideal radiation angle will do best.
From Houston, Texas I am somewhat landlocked towards Europe. Overall 17 degrees does well but moreso on 20 meters. I do not have the space to get close to this angle on lower frequencies. Any efficient vertical with suitable counterpoise seems possible on 20 meters.
With today's and foreast solar conditions, for me DX is relative to 20 meter propogation.
Not overly encouraging but interesting nevertheless !
Frank, K5OX
by W5DXP on November 25, 2013 Mail this to a friend!
Here's what EZNEC said about my 40' high horizontal 130' ladder-line-fed dipole used on 40m, vs my 33' vertical with 8 radials elevated at 20'.
http://w5dxp.com/dipvsver.htm
Virtually all of my A/B tests agree with EZNEC. The vertical hardly ever beat the dipole in the dipole's favored E/W direction. The vertical almost always beat the dipole off the N/S ends of the dipole. Seems such should be standard knowledge by now.
by K1DA on November 25, 2013 Mail this to a friend!
The polarity of the antenna at the OTHER end only matters with line of site and "ground wave" paths. Even "single hop" propagation causes polarization shifting.
I recently read that at the right height, a single dipole has 6 or 8 dbi gain broadside, far from an isotropic radiator. OTOH, a low dipole is a cloud warmer (aka NVIS antenna).
I couldn't help but notice those 17 degree +/- lobes!
by JOHNZ on November 25, 2013 Mail this to a friend!
@N4UFO
You made three separate postings in a row on the same topic. What are you trying to say?
@WA8JXM
6 or 8 dbi !!?? In my experience, I find that difficult to believe, not impossible, just difficult. Can you quote a source for your information? That would help greatly.
by N4JTE on November 25, 2013 Mail this to a friend!
A couple of points, I chose gain antennas in the same exact location and was hoping that the verticals would outperform the horizontal wire beam.
To build the 80 wire beam needed a lot of room and permission from neighbors for tree use for the elements.
I feel that a vertical directional beam with 4 raised radials on each full size element is a Very good vertical installation.
I expected that all the low angle takeoff touted everywhere you read, would be the winner in this experiment!
Eznec is starting point but real world testing is more valuable to me.
I don't remember where I saw it recently, but a look at the ARRL Handbook says essentially the same thing: "The higher dipole [66'] has a peak gain of 7.1 dBi at an elevation angle of about 26 degrees..." (2011 edition, Fig. 21.7)
Ken
by WA6MJE on November 25, 2013 Mail this to a friend!
Living in an HOA restricted area, I have spent considerable time improving my stealth vertical "performance". Ultimately, I realized that considering the concept of evaluating an antenna installation by the signal reports of others was only HALF the story. Few if any articles focus on the other half, HOW WELL THE ANTENNA RECEIVES.
There are many options to improve your signal on the other end, not the least of which is the brute strength of sheer watts of power, or directive antennas with gain in the desired direction.
Not so easy on the received side. On that side the problem is signal to noise. Thus simply increasing received efficiency by use of pre-amps or directive antennas increases signal AND noise, and you get nowhere for marginal signals. Upon realizing this, I came to the sudden conclusion that by far, 99% of the antenna literature focused on improving radiated gain. (as does this article) and maybe 1% on improving received signal to noise ratio. Improving gain on the received side with various techniques typically improves signal AND noise an illusory benefit on the received side of things.
I point this out hoping to change the focus of antenna articles as this one. Instead of a study of how strong the signal is heard on the other side, how about more studies on how to improve signal to noise ratio on the received side? When working digital modes such as JT65 you can decode signals about -24db below the noise level and make a contact. Signals below that are lost unless I can improve signal to noise level. Flipping on a receiver pre-amp is not the solution. If I just improve antenna gain, signal and noise both increase, and the decode is still lost.
Starting to look at where the noise in my unique situation comes from, limiting that noise by antenna design, or removing the source if inside my property allowed me to make contacts that would never have been made by a design that focused on transmitter performance alone. A slight increase in transmitter power bought me above the noise level on the other side, an easy "flip a switch" solution. The solution for the other half of the contact, had no easy button.
Well verticals are usually a little noisier but in your situation I would look into passive receive loops or a beverage antenna if you have room, and trust me many articles have been published addressing your concerns.
by K9QR on November 25, 2013 Mail this to a friend!
I have had great success with my vertical I installed a couple of months ago. If I can hear them I can usually work them with great signal reports. I even have broken through big pileups with 100 watts. It is very simple and inexpensive. You can see it at http://www.qrz.com/db/K9QR
by KS1U on November 25, 2013 Mail this to a friend!
I have no doubt of the results of these specific configurations of horizontal and vertical antennas, from this location at the frequencies mentioned. However, potential vertical users should not shy away from other vertical configurations, the most common being a single 1/4 wave element with numerous radials. Experiments like the aforementioned are certainly worthwhile and interesting, but results should not be extrapolated to other scenarios.
by VE3XQQ on November 26, 2013 Mail this to a friend!
I agree that S/N ratio is critical. I have found the use of the ANC4 and a strategically positioned noise sense antenna brings my S/N ratio close to my terminated folded dipole. This is only true for near field noise, for far field atmospheric noise the folded dipole wins out.
In the end ham radio is part art and part science, this is what makes this hobby uniquely satisfying when even partial success is had.
Now let's see, how big would a helical antenna be for 80 meters.....
73 de VE3XQQ, Frank
by DL1MEV on November 26, 2013 Mail this to a friend!
Although I am very happy with my vertical antenna, I am planning to give a dipole on 80m a try after reading your interesting article.
by K8IDW on November 26, 2013 Mail this to a friend!
No, No, and No... The results may be skewed towards the horizontal in your limited tests, BUT... We all know that the omni-directional, lower angle of radiation of a vertical antenna will on most days of the week outperform horizontally polorized, high agle radiators such as dipoles. Here, I'm lucky and have 3 acres, with only 3 trees, and there isn't a tree line for almost a mile 360 degrees around my house (Flat, farmland in Ohio). My Hustler 6BTV Vertical with 3600ft of radials (sixty 60' radials), is working fantastic.
by JOHNZ on November 26, 2013 Mail this to a friend!
@WA8JXM
The article you reference was written by Chuck Hutchinson, K8CH. Chuck is a gentleman and a scholar, in addition to being an authority on antennas. That being said, I believe it was he and I at Dayton that had quite a lengthy discussion, concerning some of his findings on antennas. I respectfully disagreed with him on some of his antenna data, the article in question, I believe, could have been one of several items we disagreed on. As an aside, concerning ham radio operators, it has always been my position that if a ham is happy with a particular antenna, then that is most of what counts and is probably the best antenna for that particular amateur radio operator. Hams are, as the name implies, amateur. Thus, unlike a commercial, military, or scientific antenna scenario, a whole different and lesser standard is applied in amateur radio operations.
by AI4WC on November 26, 2013 Mail this to a friend!
I love these types of articles, and much interesting information is presented there. I just have to remember that all that is discussed is not necessarily "chiseled in stone." For instance, last weekend, the 10-10 folks were out en mass. I live on the second floor of a 3-story apartment building with a veranda facing North. I cobbled together a 10 Meter dipole (not big, right?) from aluminum electric fence wire and some old RG-58. My veranda is small, so the ends of the dipole hung down about 2 feet on each end, and the antenna was oriented East-West. I made a QRP QSO to Chihuahua, Mexico, SSB voice, with my Yaesu FT-817. The other operator was 1318 miles due West of my East-West pointing dipole. My conclusions: one can sometimes make contact with low powered radios on makeshift antennas situated low and poorly, but the only real definitive conclusion that can be made is: YOU CANNOT MAKE A QSO IF YOU DON'T TRY! That's it! Otherwise, stay civil and take all antenna evaluations thoughtfully and with realistic skepticism! Keep this wonderful hobby fun! I love it! You can too!
by K5AF on November 26, 2013 Mail this to a friend!
Perhaps a compromise might be a vertical dipole. The reason that a Dipole performs well is because the high current portion of the antenna is well above the ground, which helps minimize ground losses.
While a vertical dipole does not have the high current portion of the antenna as high as the dipole, it still is significantly higher than a vertical with radials.
While my experiments have been somewhat unscientific, I can tell you that here in Texas, a 33' vertical dipole with end loading has outperformed a vertical with 16 radials every time.
End loading can be accomplished many ways. One way is with a top/bottom hat structure, a "T" top an bottom, or a double L configuration. It all works in a very similar manner. In fact, you can mix and match end loading techniques asymtrically to suit your individual situation.
I use square hat structure, 5' on a side, with perimeter wire, top and bottom, with a dipole length of about 30'. This is a wire structure that I hang from a tree branch. Solid performer all around, but great for DX.
I use a small amount of inductance in the center to bring the dipole to resonance and feed with 300 ohm ladder line. Also works very well on 30M.
by WA1RNE on November 26, 2013 Mail this to a friend!
"The 80 dipoles were on same pole with the phased lines connected at top and running off about 60 degree angle to the mid point relay /feedpoint resulting in little or no coupling as they were at around 30 feet away from verticals on the poles."
Bob, I'd like to believe there was no coupling between the 80 meter dipoles and their feed lines to the verticals but I highly doubt that was the case.
I haven't tried it yet, but EZNEC will likely confirm there is considerable amount of pattern distortion.
You might want to try modeling your system and possibly take the dipoles down temporarily and run the test again.
WA1RNE
by N4JTE on November 26, 2013 Mail this to a friend!
I cannot guarantee that there was no coupling to the vertical elements but when I was testing with the MFJ
the vertical impedances did not change when phaselines were hooked up or not to the dipoles and vice a versa.
I am not capable of modeling phase driven vertcal or horizontal arrays, probaly a good thing as I would never have time to build them!
Owen, VK1OD was kind enough to respond to me via email.
He refers to his article on his homepage;
This article describes just one in a series of experiments, some of which compared a quarter wave vertical with elevated radials to a co-sited non-descript OCF dipole, and a half wave dipole located at a nearby site. The series of experiments did NOT support the common belief that a quarter wave vertical is much better transmitting antenna for long distance paths, in fact the experiments put a figure on it to tenths of a dB, and it was less than 3dB IIRC.
Owen
Food for thought.
by NO9E on November 27, 2013 Mail this to a friend!
There is a graph somewhere on G3TXQ page showing performance of different antennas at different heights with average soil. A dipole at half wave beats vertical all the time.
Verticals do very well in salt water.
Dipoles especially multiband have many nulls.
It is hard to get dipoles for 80 and 160m at half wave.
Vertical on the roof may beat dipole in between obstructions.
ALso, see the post of W8JI http://www.eham.net/ehamforum/smf/index.php?action=printpage;topic=76020.0
Ignacy, NO9E
by N4JTE on November 27, 2013 Mail this to a friend!
K8IDW, your comments are the exact reason I did this experiment, parroting the usual mantra "everybody knows" that verticals are better dx antennas without having tried both was my point.
You say it's working "Fantastic" and I am glad you feel that way, put up a couple of crossed dipoles and see what happens.
However,I see a total of one DX contact posted on the summits under your call for the year to date and not much interest/ lookups, on qrz.com . Usually a reasonable guideline, on who is active and being heard somewhere.
Sorry but the uniformed " NO NO NO "comment had to be addressed with some facts.
by NI0C on November 27, 2013 Mail this to a friend!
N4JTE writes:
"However,I see a total of one DX contact posted on the summits under your call for the year to date and not much interest/ lookups, on qrz.com . Usually a reasonable guideline, on who is active and being heard somewhere."
The number of QRZ.com lookups and number of contacts "posted on the summits" is a actually a very poor measure of someone's DX activity and/or station effectiveness. Very few DX'ers "post" their logbooks on the DX clusters, and this practice is frequently criticized.
DXCC and WAZ scores can be checked on the ARRL and CQ websites, and Club Log also compiles more informal statistics.
by PA1ZP on November 27, 2013 Mail this to a friend!
Hi all
I do not know how long you tested them.
I had a 80/40 mtr vertical many years and it was a aluminium structure.
SWR on 40 mtr with 1/2 wave high impedance tuning direct at the vartical at the antenna
SWR on 40 mtrs below 1.4 at band ends,
on 80 mtrs no tuning SWR below 2 at band ends
Had rotatable aluminium dipole for 40 mtrs at 40 feet.
In DX above 4000 miles the vertical won very easy on 40 mtrs most of the time.
But there were occasions that the dipole would win.
And sometimes these antennas were a match.
I think it depends on condx. and you need to spend more then a few years in geining experience.
But keep it very simple, yes you can meke excelent DX on 40 and 80 mtrs with horizontal polarised antennas.
But as we had a daily sked on 20 mtrs with PZ (Surinam) at a distance of 4000 miles+.
i know from experience that every time we made a sked from PA to PZ on 40 mtrs after our QSO on 20 mtrs at midnight 23.00 UTC in PA to PZ I could work my friend every time,on the vertical, but only half of the times I could work him with the dipole, though I usualy could hear PZ on both antennas, he could not copy me on the dipole and he could hear me on the vertical.
Tests were done the whole year through.
We made these contacts with more radio friends whom were limited to wire dipoles, they often couldn't even copy PZ while i was working him.
But as you say very clearly , you did have a nice set of dipoles, that helps a lot to certainly on 40 mtrs.
In winter time we prefered 40 meters as often condx on 40 meters were much better at 23.00 UTC as they were at 20.00 UTC on 20 mtrs.
Pse look for our time zones PA is -1/-2 UTC and PZ is +3 UTC.
by W8DPC on November 27, 2013 Mail this to a friend!
There are so many variables that it almost seems pointless to try to compare antennae. You've got the quality of the antenna, type of antenna, quality of your installation, your location (both local terrain and where you are in the world), transmitters within range that might affect your reception, propagation, the equipment of the other operator you are talking to, etc., etc., etc. Even solar activity ,time of day, and weather can affect a contact with a specific station from one hour to the next. The variables are almost endless.
"There are so many variables that it almost seems pointless to try to compare antennae."
It may be better to state what variables affect the comparisons than state that they are pointless. IMHO the comparisons by N4JTE were well decribed. All details provided. Dipoles were high. Favored directions tested. Results as expected based on dipole heights and average ground.
The vertical will beat a dipole that is too low or has a null in the required direction. Especially multiband dipoles have many nulls.
Ignacy, NO9E
http://karinya.net/g3txq/temp/angle_of_arrival_stats/aoa_dipole_elevations.png
by K9MRD on December 2, 2013 Mail this to a friend!
RE: NO9E
Nice Graph
by W3DIY on December 2, 2013 Mail this to a friend!
Excellent!! I was impressed with your observations until modeling was mentioned. I learned on a 5 acre lot with an abundance of 100í tall trees with large trunk diameters and the poorest soil conditions modeling is useless here. Coupling with all of this nature nearby the Z of a base fed vertical is typically 10 ohms or less.
While making A/B comparisons with as many wire antenna designs that would fit on 5 acres if someone asked which is the best for DX my reply would be at this very minute itís **** in 15min. it may be *** and tomorrow they may be equal.
To borrow a comment from a previous post to this threadÖit depends.
by N4JTE on December 2, 2013 Mail this to a friend!
DIY, totally understand your comment, what was presented was for around 3 months, but after 30 years,and many stateside and international qth's the only Vertical that became my primary was a location on a out island in the Bahamas.
Would have been a really boring article with 30 years plus of DX contacts validating the point, hi
Repectfully,
by W4MY on December 3, 2013 Mail this to a friend!
Its all about the angles, gents. From THIS locaton, with THIS setup, and THESE ground conditions, obviously the the take off angles of the major energy lobe from the dipoles were more optimum than from the verticals for the desired destination.
There are MANY antenna design decisions that can be made to get the best RF energy angle into the destination you desire. Both horizontal and vertical antennas can be used to achieve your desired result.
by N4JTE on December 3, 2013 Mail this to a friend!
I approached this experiment with no agenda other than to present my results from my backyard.
I do hope when a new ham reads just about everywhere, especially the vendors, that verticals are the best antenna for DX they take a second look and understand the physics and luck required for a vertical to meet or exceed a well place dipole.
by W6QW on December 3, 2013 Mail this to a friend!
As they say, your mileage will vary. Bringing up the subject of which antenna is superior is akin to discussing politics or religion.
With that said, N4JTE provided an observation based on his conditions alone and is viable as a benchmark for others to consider. Had he run the same test at the edge of a salt water environment, the results would have been different.
by JOHNZ on December 3, 2013 Mail this to a friend!
@W6QW
Pulleeeeeze!
This was a casual experiment, conducted under unscientific conditions and lacking any formal engineering practices, which makes it not even close to what would be considered a "benchmark."
Well johnz or whatever, give us a real world test link that disputes my "casual" results.
bob
@N4JTE
Sure, but first let me know which Engineering Journals accepted your findings for publication? Hint: QST, CQ Magazine, and your ham radio club newsletter are NOT engineering journals.
by W6QW on December 4, 2013 Mail this to a friend!
Robert - it sometimes best to ignore those with idiopathic inclinations
by JOHNZ on December 4, 2013 Mail this to a friend!
@W6QW
What a profound benchmark remark!
by KV2T on December 4, 2013 Mail this to a friend!
Hi Bob, when I was on LI I had run a pair of phased verticals, they are great for when the band opens and closes, the lower angle gain is not all that good when the band is opened well from what I have seen, 4 sqrs do better but hi horizontal antennas seem to work better. Since I have been here in Carmel, ny a horizontal rectangular loop seems to work best facing ENE/WSW on 75mtrs at 65'. Will be placing a 40mtr loop up soon about 70' high, I would love to phase a pair but don't have the room and feel that there would be to much interaction between too many antennas so close together. That is why your verticals seem to suck wind in the reports as well, they act as extra ground screens for your horizontal dipoles but the dipoles are masking your verticals performance. to do these typle of tests right you need to get a larger yard and space them much farther away. Thats why I am sticking with just the loops here on a 1/2 acre plot, the loops are less prone to interaction. On 75mtrs a pair of inverted L's would phase real well and your take off angle would be around 30 degree's which woulod work here on the east coast better than two full size verticals for most dx thats on the band.
CUL
Jim
KE2TR
by N4JTE on December 5, 2013 Mail this to a friend!
Jim all good info, feel free to join a dx group on 3788, give or take usually tabled by G0EVY and starts when he gets on 9 or 9.30 pm our time.always talking antennas and whateverelse we can think of hi.
by K1DA on December 6, 2013 Mail this to a friend!
Antenna articles run from the "my double zoomie DX 9000 G5RV works better than my Gotham Vertical so dipoles "win" to "What does the VOA use to cover North Africa day after day on 31 meters" from North Carolina. Of the two, there is more to be gleamed form the VOA article. For amateurs, half the battle is piclking an antenna which will work on your property. Verticals are easier to put up, but the radial systems require work for the system to be efficient and their "local rag chew performance" is poor due to a lact of high angle radiation. That is pretty well understood. Dipoles have to be high on the lower bands to work well FOR DX, but even a low dipole will provide local coverage unless the antenna is so low efficiency suffers. Once yo understand what particular antennas can and cannot do well, you you decide what application you want the antenna for, you can make an informed decision.
by KF7VXA on December 9, 2013 Mail this to a friend!
If YOU CARE TO TRANSMIT IN JUST TWO DIRECTIONS WITH MAXIMUM SIGNAL AND HAVE ALL THE SPACE AND POLES/TREES TO HANG YOUR TWO DIPOLES, THEN THE DIPOLES MIGHT BE THE BEST OPTION IN MANY, BUT NOT ALL CASES.
PROBLEM IS, MOST DON'T HAVE THAT KIND OF ROOM OR ABILITY TO GET THE VERTICALS UP HIGH ENOUGH.
A VERTICAL TRANSMITS FAIRLY PRETTY MUCH 360 DEGREES WHICH IS A MAJOR THING FOR SOMEONE LIKE ME WITHOUT THE ROOM.
THEN ONE MUST LOOK AT ALL THE DIFFERENT TYPES/BRANDS OF VERTICALS. SOME WORK MUCH BETTER AT SOME FREQUENCIES THAN OTHERS. YOU ALSO HAVE VERTICALS LIKE THE GAP THAT DON'T DEPEND ON THE GROUND MUCH AT ALL AND BEING VERTICAL DIPOLES, ARE FAR QUIETER THAN MOST ALL OTHER VERTICALS AND STILL HAVE A GOOD LOW TAKE OFF ANGLE.
AS WAS MENTIONED, LOCATION, GROUND, HILLS, MOUNTIANS, SALT WATER AND ALL THE DIFFERENT PROBIGATION DUE TO MANY FACTORS AND I DON'T THINK IT MEANS ALL THAT MUCH EXCEPT IT WORKS GREAT FOR YOU IN YOUR LOCATION AND YOUR SITUATION.
I DO THINK THAT FAR MORE ROOM WAS NEED BETWEEN THE TWO DIFFERENT TYPES OF ANTENNAS AS INTERACTION WITH THE VERTICALS FROM GUY WIRES ETC. WILL BE A FACTOR.
THANKS FOR THE TEST, BUT TO ME, EXPERIMENT WHERE YOU ARE, DO THE BEST YOU CAN WITH THE ROOM YOU HAVE AND DON'T COUNT ON WHAT OTHERS HAVE FOUND WHERE THEY LIVE.
73'S JOHN KF7VXA
by N4JTE on December 9, 2013 Mail this to a friend!
I think you missed the point of the article; a lot of advertisements and elmer advice always starts off with the statement that verticals are better for dx.
The experiment was conducted in my backyard with is a pretty typical size for most to try the antennas as described.
The chart shows my experience and there was little mutual coupling as measured with the mfj.
Try an inverted vee instead of your vertical and you might get your lookups beyond 6.
Glad to hear there was not much mutual couplings. Everything I've read says that anything vertical should be kept a good distance away from each other. I've read this more than a few places so either the authors are wrong or I am, but I really don't care as I make it a point for good separation of my two verticals. Antenna analyzers don't show what signal patterns look like. That's why I asked the question, not to try and rip you one, but to learn.
The jab about my look ups being more than 6 is the kind of thing that makes some just give it all up. I may be new to HF, but that does not mean that I have not been around other Hams for many years.
I have more look ups other places, but that's not why I'm on the air and don't gauge my skill or manhood on the number of look ups. I enjoy a good round table much more than contesting. I've made quite a few DX contacts and enjoy just knowing that I was able to make contacts on the other side of the world. Contesting is not my thing. It's darn tough to have a decent conversation with a DX contact because as soon as you make a contact, there will be a pile up from small to large and when that happens, I'd just as soon sign off and give others who may really need the contact the chance, I'm just there for a rag chew. I only send QSL cards if asked.
You posted your results, I didn't berate anything you said, only pointed out that many do not have the room or physical ability for that matter to put the wire in the air that you did. I do prefer to hear signals from all directions and hope some day to get something directional and movable up when I'm able. For the time being, I can switch to other antennas to see if one of my more directional antennas gets a better signal and also to see if I can hear the other station as well.
Also as was stated by many, different locations, types of antennas etc. can produce different results.
Sorry if you got your bloomers blow up, that was not my intention. I use both my vertical and a few dipoles and one may be better than the other one day, but not the next. As long as I'm happy with the contacts made, that all that really matters to me, not what anyone else thinks; using the antennas I have works great for me. Right now it's 18 below zero. I'm not much in the mood to try anything new till spring. I've got 6 through a decent portion of 160 covered by about 5 different antennas. May not be yagi's on a tower or dipole's all at 50 plus feet in the air, but they work for me.
Anyway, 73's John KF7VXA
John my bloomers are fine, your the one that sent off the CAPS on your response, understand one thing if you have an open mind as a new ham, a vertical is the hardest antenna to build that will ever match any advertisements or everything you read on the internet claiming it is a superior dx antenna, it takes a superior, labor intensive ground system to make up for ground losses, secondly any vertical antenna needs to have a far feild reinforcing wave to add any kind of gain, always hit and miss from our backyard. We have no ability to match vertical advertisements unless lucky enough to be on some island in the middle of the ocean.
Basic stuff, get the max current point as high as you can if able simple physics.
Final point, do both and write your own article, try an inverted vee versus a comercial vertical and report back be good to see how things work from your location.
by KF7VXA on December 10, 2013 Mail this to a friend!
Bob,
I do have inverted v's as well as regular dipoles. I also use a Gap Challenger vertical that does not require the ground field of other verticals and is a vertical dipole fed from the middle. Some don't care for the Gap, but it has done exceptionally well in making DX contacts. The numbers I get are much like your verticals, not 20 over 9's very often, but the important thing is that I still make the same contacts, a lot of 5-7's and 5-9's.
I live on a valley floor with tall mountains (up to 14,000' on 3 sides of me. The open end is on the other side of the valley. Look at Google Earth, Victor, Idaho.
I don't get VHF/UHF in or out of the valley except on the open side (and repeaters). I have yet to get any 6 or 10 meter activity with dipoles or the vertical.
12 meters is as high as it gets. All antennas did great during the 15 meter opening about a month ago, signals everywhere on the band and DX was great. 20 and 40 were fantastic also. Still decent, but not like it was.
With everything being cyclic, it always depends on many things as to the distance and countries that can be contacted.
Your experiment was a good one, but I doubt you would have the same results where I live.
73's John KF7VXA
I should add that I've made contacts in most areas of the world (not every county) except the Aussy's and Africa. I also made contacts with the majority of the states including Alaska and Hawaii. I will need a NVIS for a couple states next to mine.
So, with what I have and 100 watts, I'm not doing too bad. It can always get better.
John
by W8IFI on December 16, 2013 Mail this to a friend!
Always a fun topic and sure to bring up a lot of friendly conversation. I enjoy hearing about various configurations that others have tried and their results. It also encourages us to do a little experimenting of our own with something different. After all, we start in the manual with a theoretical point of perfect ground, which can vary, so where that is exactly no one knows. We begin with an assumed and maybe not accurate starting point. So to demand that everything be tested and measured to the nth degree with $20,0000 worth of test gear at umpteen different points and have results published in scientific journals before they take the persons word for it,indicates perfectionist people with a serious problem!
If someone says here is what I found I have no trouble accepting that as a starting point. I don't have to always put people on the defensive and go through their statements with a fine tooth comb looking for proof. This is a hobby, not a physics research lab or courtroom.
by JOHNZ on December 17, 2013 Mail this to a friend!
@W8IFI
Amateur radio experimentation is desirable and a historic part of our hobby. The single most important distinction to remember, however, is the world of difference between ham radio experimentation and professional engineering research, development, evaluation, and testing. Hams are not required to adhere to scientific and engineering rules and should not be, thus ham radio experimental results cannot and should not be accepted as scientific fact. That being said, any ham who shares his experimental results here should have thick skin and accept constructive criticism, a.k.a. having emotional maturity.
by LEON on December 18, 2013 Mail this to a friend!
THIS IS JOHNZ:
@W8IFI
________________________________________
THIS IS LEON:
Dude really?
Being thick skinned, accepting constructive criticism, and emotional maturity are not your strong points John.
Thanks for the advice though.
LEON
by JOHNZ on December 18, 2013 Mail this to a friend!
Hi Leon,
Feel free to share your opinions with me whenever you wish. My skin is as thick as they come. Got that way after 20 years military service, retired E-9, followed by almost three decades in corporate America and federal civil service. Cheers!
CHEERS
by LEON on December 19, 2013 Mail this to a friend!
JOHNZ:
Hi Leon,
LEON:
Thanks for your service John.
My best 73 to you and your family, and God Bless!!
Merry Christmas!
LEON
by KD4IEM on December 22, 2013 Mail this to a friend!
My view is this is an Apples and Oranges comparison.
Everybody knows that to achieve maximum efficiency with a Omni-directional vertical antenna you are required to have at least 120 ground radials. Also, the dipole functions as a balanced radiator and does not rely on ground interaction to function at its full efficiency.
This comparison sets up the vertical to function at a reduced efficiency.
A more proper comparison would have been to have two completely separate antenna's at different locations that would not interact with each other, and the vertical located at ground level instead of elevated with a measly 4 radials in a ground plane configuration.
Its difficult to see how one can derive a accurate conclusion based on one antenna designed with built-in in-efficiencies.
by N0AZZ on December 23, 2013 Mail this to a friend!
On 40m I use a hi Gain Hy Tower with 48 1/4w radials and a 3 element 40m beam at 60' and I'm a DX'er. In comparing the two of them for the last 5 years I have found that the vertical will match the beam about 60-70% of the time on DX over 2500 miles. I do use both of these antennas for duel receive with my K3's excellent combination.
For 80m I have 3 antennas the vertical and 2 wire antennas a 1/4w 80m and a 270' OCFD both at 65'. Again the vertical out preforms the others hands down by quite a bit.
I do live in the country on a farm in a very quite area with the closest house to me over a 1/4 mile away and that's to close 8>).
As always YMMV
Fred/N0AZZ
by KV2T on December 23, 2013 Mail this to a friend!
Yes Bob I will try to get on 75 at night, I still feel on 75 a pair of phased L's would work better than my rectagular loop but I would give up the rag chew antenna for stateside contacts, the loop is kind of a mixed bag and if I could fit 130 center fed flat top it might do better but dont have the room. I did install a 40mtr inverted delta up 75' which I fed at the bottom center and have two high supports which works real well so far. Not knowing what the ground conductivity here at my qth and just going by the soil here I would say that the horizontal antennas do better. In ON4UN's low band DX book he h=goes into loops and both types of fed systems and the vertical style feed will work the best under very good ground conditions but when you look at his charts under poor ground they suck. When I was on LI the only verticals that worked well were with elevated radials or an intense ground screen system, here again soil there was sand. Moving up here I lost 5db I feel from long island, great radio qth but way to many live there and I would rather have the breathing room up state. When I built my contest station back in the 90ies I proved real well what LI was worth and what I had up would have had to been up higher and larger in size if up here. Back then two crank ups and 9 yagi's layed down a signal that would compete with some of the best east coast stations and on 75 I ran two pahsed inverted vee's up 80' and the ends were 40'. Here again the verticals work real well on band openings but once the band opened the vee's would hang the some of the best plus they would still have some hi angle that would keep the frek clear from local's. I feel that which is better depends on your qth and the soil conductivity unless you ar willing to lay tons of copper in the ground.
Jim
KE2TR
by W8IFI on December 27, 2013 Mail this to a friend!
Who here would accept a Ham's casual experiments as scientific fact? Only someone who is emotionally unsure of himself would have to give credentials, personal history to show they speak with authority and point out perceived flaws in methods. Hams usually can mentally separate fun from laboratory results. They don't have to put themselves on a pedestal.
by W5EN on January 2, 2014 Mail this to a friend!
An amusing test that I enjoyed reading. It would apply to my station more if I did not live on a city lot, if I had room for 2 phased fed dipoles at 40 feet, and if I did not have neighbors to complain about a wire array. In the meantime I'll continue to use my single 6BTV, buried radial system, and single feed system. I enjoy both CW and SSB contacts on all ham bands from 40 meters to 10, something your dipole array will not accomplish. I've worked over 250 countries using this station and a 500 watt amp. My point is that there are many factors that affect our antenna selection.
73 de W5EN Steve
by W6PU on January 5, 2014 Mail this to a friend!
I loved reading this antenna thread, and would sure like
to see more of them.
First licensed( K2DGT ) in 1953, I guess that this makes me an O.T-Ha! Love chasing DX, and find the 160,
80' and 40 Mtr. bands to be most challanging.
On these bands in particular, have found over 60 years of DXing that unless I could get my low band dipoles up at least 1/2 wave length, where they would start to develope some low wave angle output, that they could not compete with my home brew verticals in DXing, or DX contesting on the low bands.
For low angle work, short of a LF Vert. array, a couple of end fed long wires always did a decent job for me.
I have found this to be true: Big signals don't just happen. They are usually the result of many hours of hard work designing and building your antenna set up!
Some of you might enjoy reading of my low band Vert. set up on my QRZ.Com Bio.
Cheers!
Bob / W6PU
Cheers!
PS: Sorry, I forgot to add this: When I speak of using
an end fed long wire for 160, 80, and 40 Mtr DXing, I qualify this as meaning at least one full wavelength on the lowest frequency.
73/W6PU
The Inverted Hell Antenna
Radiant Barrier Myth
