Testing Jig Eases Job of Measuring Junk Box Resistors:
from The ARRL Letter on February 21, 2019
Paul Danzer, N1II, was faced with sorting a box of 100 old resistors to verify their approximate values. The idea of attaching digital multimeter clip leads to each resistor 100 times was not very appealing. His solution was to build a fixture from thin sheet aluminum. Each leg is approximately 1 inch wide, and the tops are bent over to eliminate any sharp edges. The meter leads are clipped to each leg. To measure a resistor, all you have to do is lay it across the two legs. If the connection seems a little less than solid, a bit of finger pressure applied to the resistor might help. Quick and easy!
Upcoming ARISS Contact with Ulluriaq School in Kangiqsualujjuaq, Quebec:
Bouvet Island DXpedition Now En Route:
ARRL Volunteer Monitoring Program:
In Search of Our Young Ham of the Year:
Ham Radio Operators Spring Into Action When Weather Becomes Dangerous:
