Propagation Forecast Bulletin #11 de K7RA:
from W1AW Bulletin via the ARRL on March 15, 2019
ZCZC AP11
Propagation Forecast Bulletin 11 ARLP011
>From Tad Cook, K7RA
Seattle, WA March 15, 2019
SB PROP ARL ARLP011
ARLP011 Propagation de K7RA
Sunspots reemerged for 8 days on March 5-12. Average daily sunspot numbers rose from 4.4 in last week's bulletin to 9.9 this week (March 7-13). Average daily solar flux barely changed, from 70.6 to 70.9. Average planetary A index declined from 12.6 to 5.1, and average middle latitude A index from 9.7 to 3.9.
The Vernal Equinox will occur next Wednesday, March 20 when the southern and northern hemispheres will be bathed in equal amounts of solar radiation.
Predicted solar flux is 70 on March 15-17, 68 on March 18-22, 69 on March 23-28, 70 on March 29, 71 on March 30 through April 8, 70 on April 9, 69 on April 10-24, 70 on April 25 and 71 on April 26-28.
Predicted planetary A index is 12, 8 and 8 on March 15-17, 5 on March 18-19, 10 on March 20, 5 on March 21-25, then 12, 30, 28, 14 and 8 on March 26-30, 5 on March 31 through April 1, 8 on April 2-3, 5 on April 4-9, then 12, 10 and 8 on April 10-12, 5 on April 13-15, 10 on April 16, 5 on April 17-21, then 10, 26, 24, 12 and 8 on April 22-26 and 5 on April 27-28.
Geomagnetic activity forecast for the period March 15 to April 13, 2019 from F.K. Janda, OK1HH.
"Geomagnetic field will be:
Quiet on March 22-24, 31, April 4-9. 13
Quiet to unsettled on March 16-18, 25, April 1-3, 11-12
Quiet to active on March 19-21, April 10
Unsettled to active on March 15, 26, 29-30
Active to disturbed on March 27-28
"Solar wind will intensify on March (15,) 21-22, 25-28, April 1, (2, 5)
"Parenthesis means lower probability of activity enhancement."
Australia's Space Weather Services issued a geomagnetic disturbance warning at 0003 UTC on March 15: "Increased geomagnetic activity expected due to coronal hole high speed wind stream on March 15-16, 2019.
"15 March: Unsettled to Active, possible Minor Storm periods for High latitudes. 16 March: Quiet to Unsettled"
Jim DeYoung, N8OQ sent this interesting question on March 13:
"I have been wondering about the fact the north magnetic pole has been shifting towards Russia significantly and therefore are there any expected resultant significant shifts in the auroral oval that would affect propagation to/from North America or to Asia?
"The reason I ask is I made probably my best QSO of all time a few weeks ago during the CQ 160m Phone contest. I always run QRP for that contest as a good test of my operating skills (ears), noise levels, rigs, and most importantly my antenna. I have used for many years a 93-meter horizontal loop fed with about 24 meters of window line up generously about 13 meters. The 'loop' is kind of more like a trapezoid but actually what is called a scalene.
"For my station I had very good propagation conditions for the CQ 160m Phone contest. Heard ZF9, ZF2, PJ4 (2x), TO4, C6, HQ9, OK7 and others I didn't write down. Didn't work any of them as expected at 5 watts QRP phone.
"However, on February 24 at 0417 UTC I worked UA7K with 5 watts on 1.838 LSB! At his twilight sunrise on the north-east side of the Black Sea. Apparently one of those fabled 160m enhancements at a station sunrise/sunset. Easy! Called once not expecting a thing. A short pause on his end. I hear N8OQ. I give RR. He gives me his CQ Zone 16. I report Victor Alpha Virginia. He gives roger and in the log he goes. LOTW QSL received a few days later! WOW!
"The QSO was so easy I soon began to think I must have been hearing things, got the call sign wrong, something.
"I heard no big guns work him, but I heard at least one other run-of-the-mill U.S. station work him for the few minutes I paused to monitor him. When I checked again about 15 minutes later he was gone but I then heard a Czech station and a Lithuanian but didn't get them. Both also near their twilight sunrise line. My antenna and low noise floor allow me to hear these stations that few if any others were calling. The UA7K clearly also had a very low noise floor but is apparently one of those super contest stations, Russian Contest Club. My 5 watts not enough to work any others of the good DX stuff--too bad! I was tempted several times to turn on the amp but resisted! This is currently my best of all time QSO.
"Was this QSO assisted by the auroral oval shifting away from the transatlantic path?"
I didn't have an answer for Jim but wanted to pass this on to readers.
Interesting article about solar activity from Canada's CBC:
https://www.cbc.ca/news/technology/solar-activity-1.5049337
Thanks, David Moore, for sending this link concerning massive solar storms:
https://www.sciencedaily.com/releases/2019/03/190311152744.htm
The latest video from Dr. Tamitha Skov, WX6SWW, can be found at, https://youtu.be/TSDfL9cwzEU .
Sunspot numbers for March 7 through 13, 2019 were 14, 11, 11, 11, 11, 11, and 0, with a mean of 9.9. 10.7 cm flux was 70.9, 71.8, 70.7, 71.1, 70.4, 70.7, and 70.8, with a mean of 70.9. Estimated planetary A indices were 8, 5, 5, 4, 3, 7, and 4, with a mean of 5.1. Middle latitude A index was 5, 3, 4, 3, 3, 5, and 4, with a mean of 3.9.
Amateur Radio 'Hamfest' Set for March 23:
New 47GHz and 122GHz Records Set in VK:
Ham Talk Live #157 -- Youth Contest Team:
Ham Session: Socializing via Airwaves:
Photos: Ham Radio Operators Train for the Worst:
