Yes that's it,
I finally purchased the k3s for the remote site and the k3/0 mini for the control site. Then, to my chagrin, I ran into an issue with the Verizon router. To run remoterig, you need to be able to program the router to port forward three remoterig apps. But when you configure the router port forwarding, you need to enable both tcp and udp protocols. The Verizon router allows you to select one protocol, but not both. So I returned it, and when I return from my Christmas trip, I will by a commercial router that will allow me to program the port forwarding correctly.
I'm almost there, but I'm just staring out with a 103 ft doublet for an antenna. I'm shooting for the towers to go up in 2016. This has turned into a big project! We get a lot of lightning, and I have even begun to address this issue....
