Author Topic: Alliance HD 73 rotor  (Read 4254 times)
WA2KDB
« on: March 22, 2015, 08:40:49 AM »
Can I use and  eight wire control box with this rotor?
 There is an eight inch stub hanging from the rotor but
two wires are hanging loose. Looks as if they were never used.
W9NWR
RE: Alliance HD 73 rotor
« Reply #1 on: March 22, 2015, 10:44:52 AM »
K0EKL
« Reply #2 on: March 23, 2015, 11:30:45 AM »
The HD-73 uses 6 wire cable. You can use 8 wire cable and leave two wires disconnected.
You CANNOT use an "eight wire control box" like the controller for a HAM-4 rotator with an HD-73. They are completely different and incompatible. Only the control box designed for the HD-73 will work.
