Author Topic: PIC18F4550 microcontroller  (Read 24074 times)
KD7RDZI2
« on: August 17, 2015, 02:11:00 PM »
Have a couple of prototype board for developing USB applications with a PIC18F4550 microcontroller made by Olimex. To program it, you can do this without any additional programmer. Is there available any program to load for ham applications?
ZENKI
RE: PIC18F4550 microcontroller
« Reply #1 on: August 20, 2015, 05:13:38 AM »
In circuit serial programming is the way to go. Use a Pickit2 or 3 or a clone. However once you start playing with PIC's a ICD2 or 3 With MPLAB is the way to go. You can buy these programmer clones on Ebay pretty cheaply.
KD7RDZI2
« Reply #2 on: August 20, 2015, 01:28:30 PM »
Actually the  PIC18F4550 microcontroller board by Olimex is meant, as far as I understand it, to be programmed via the USB port without any additional programmer. The idea is great, but where can I find a reliable repository of software for this PIC which may fit some hams needs? Eg. DDS controller, keyer, relay switches, sequencers etc.
KD7RDZI2
« Reply #3 on: September 15, 2015, 02:09:24 PM »
Indeed good advises, programmed the PICs via a programmer to control DDS AD9951 !!!
