Author Topic: Heathkit HM-15 SWR Meter Question  (Read 3512 times)
W3ESE
« on: January 18, 2016, 10:34:29 AM »
This is probably a dumb question, but how does one set up the Heathkit HM-15 Reflected Power and SWR Meter to read SWR & Reflected Power?
The manual says to set the function switch to FWD, and adjust the sensitivity control to give a "full scale" (set) meter reading....That`s it....So the meter reads "full scale" all the time when transmitting...The instructions give no further indication as to how to get an actual SWR reading.
This is difficult to describe, but I`m sure a HM-15 owner will step forward with an explanation that will make me feel like I`m brain-dead.
« Last Edit: January 18, 2016, 10:55:30 AM by W3ESE »
K7MH
RE: Heathkit HM-15 SWR Meter Question
« Reply #1 on: January 18, 2016, 11:52:49 AM »
You're half way there...
Then set the switch to "Rev" for "reverse" or reflected power and see what the meter reads.
W3ESE
« Reply #2 on: January 18, 2016, 12:19:09 PM »
I`ve done that, and it stays at the "set" mark...However, I just discovered my mistake.
The manual says to install it before the antenna tuner..In as much as my rig is a IC-756pro2 with a built-in tuner, that wasn`t done.
I just now disengaged the rig built-in tuner, and installed a manual tuner (after the HM-15) that I had laying around, and bingo. Solved.
« Last Edit: January 18, 2016, 12:48:10 PM by W3ESE »
