Interesting thread. I am not active on APRS but I like the concept the original poster raised. I wonder if he has the equipment to run 300 Baud Packet instead of 1200 Baud? If so, could try his experiments on 10M FM too ....
Interesting, I had not thought about using 300baud packets....that might make the packets more successful and less subject to the static and noise. Although the bandwidth of FM is quite a bit wider than SSB, therefore a larger noise floor is included with the FM signal...FM receivers on the other hand require a fairly low SNR before the signal is accepted, this of course causes further limitations in range, basically about 12db more signal than SSB is required to pass through an FM receiver.
So all of that said, 300 baud packets over 6m or 10m SSB might be the answer, although I am not sure if I can generate 300baud APRS packets and decode them..I will have to look at the software and see what I can do.
6m SSB was pretty reliable at 12 miles yesterday. Today we are trying 2m FM again with better antennas, initial results where not impressive...8 miles in the rolling terrain area....
Over the weekend I am going to install a 200watt 2m linear in one of the vehicles. In theory this should easily reach the other vehicle on 2m FM over a 15 mile path, the receiver pre-amp in the linear "may" allow the weaker mobile to be received at the high power mobile...we will test this using FM on Monday and then try SSB the following day.
I have always been a believer that if you can raise an antenna to at least be clear of the trees, power is not really an issue....but with two mobiles, we are limited with what we can do with antennas and modes....the next logical step is to "pour the coal" to it and a 200 watt amp is certainly going to pour the coal to it!
