ANNUAL ARMED FORCES DAY CROSSBAND MILITARY/AMATEUR RADIO COMMUNICATIONS TEST
(14 MAY 2016) The Army, Air Force, Navy and Coast Guard are sponsoring the annual military/amateur radio communications tests in celebration of the 66th Anniversary of Armed Forces Day (AFD). The AFD Military/Amateur Crossband Communications Test is conducted 14 May 2016.
The annual celebration is a unique opportunity to test two way communications between Amateurs and military communicators authorized in 47 CFR 97.111, and features traditional military to amateur cross band SSB voice, Morse Code, practice using legacy interoperability waveforms, as well as an opportunity for Amateurs to utilize more modern military communications modes such as MIL-STD Serial PSK and Automatic Link Establishment (ALE). New for Armed Forces Day this year, military stations and amateur radio operators are authorized to directly communicate on the 60 Meter interoperability channels.
These tests give Amateur Radio operators and Short Wave Listeners (SWL) an opportunity and a challenge to demonstrate their individual technical skills, and to receive recognition from the appropriate military radio station for their proven expertise. QSL cards will be provided to those stations making contact with the military stations.
PART I. MILITARY-TO-AMATEUR CROSS BAND SSB & CW TEST CONTACTS.Military-to-Amateur cross band operations will take place on the dates/times in ZULU (UTC), and frequencies listed below for each station. Voice contacts will include operations in single sideband voice (SSB). Some stations may not operate the entire period. Participating military stations will transmit on selected Military frequencies and listen for amateur radio stations in the Amateur bands indicated below. The military station operator will announce the specific amateur band frequency being monitored. Duration of each voice contact should be limited to 1-2 minutes. The following stations will be transmitting on MARS frequencies listed below which are provided as "Window/Dial Frequency" in kHz. Some stations will use CW to provide the opportunity to check in by Morse Code.
ARMY STATIONS:
AAZ / FT HUACHUCA, AZ
(14 MAY 1500Z - 2359Z)
FREQUENCY EMISSION AMATEUR BAND
5,330.5 kHz USB 60M
14,383.5 kHz USB 20M
18,211.0 kHz USB 17M
AAC / BARROW ARMY RESERVE CENTER, KY
(14 MAY 1300Z - 15 MAY 0100Z)
5,346.5 kHz USB 60M
7,360.0 kHz USB 40M
13,963.5 kHz USB 20M
20,920.0 kHz USB 15M
AAV / CAMP EVANS, NJ
(14 MAY 1400Z - 2100Z)
5,330.5 kHz USB/CW 60M
7,493.5 kHz USB/CW 40M
14,846.0 kHz USB/CW 20M
18,272.0 kHz USB/CW 17M
ABH / SCHOFIELD BARRACKS, HI
(14 MAY 1600Z - 2300Z)
5,357.0 kHz USB 60M
14,438.5 kHz USB 20M
18,272.0 kHz USB 17M
20,997.0 kHz USB 15M
ADB / CAMP FOSTER, OKINAWA
(14 MAY 1500Z – 15 MAY 0100Z)
14,487.0 kHz USB 20M
17,545.0 kHz USB 17M
20,994.0 kHz USB 15M
WAR / PENTAGON WASHINGTON, DC
(14 MAY 1200Z - 2400Z)
5,357.0 kHz USB/CW 60M
14,854.0 kHz USB/CW 20M
18,211.0 kHz USB/CW 17M
24,760.0 kHz USB/CW 12M
WUG-2 / ARMY CORPS OF ENGINEERS, TN
(14 MAY 1300Z-15 MAY 0200Z)
5,403.5 kHz USB 60M
13,910.5 kHz USB/CW 20M
18,293.0 kHz USB/CW 17M
20,973.5 kHz USB/CW 15M
ALT/ CAMP MABRY, TX
5,357.0 kHz USB 60M
14,512.5 kHz USB 20M
18,293.0 kHz USB 17M
AIR FORCE STATIONS:
AIR / ANDREWS AFB
4,517.0 kHz USB 80M
7,305.0 kHz USB 40M
15,807.0 kHz USB 20M
20,740.0 kHz USB 15M
AGA2SY / HANCOCK FIELD, NY
(14 MAY 1200Z TO 2400Z)
4,575.0 kHz USB 80M
7,540.0 kHz USB 40M
13,993.0 kHz USB 20M
AGA4AR / ARNOLD AFB, TN
(14 MAY 1500Z TO 2000Z)
3,299.0 kHz USB 80M
7,457.0 kHz USB 40M
15,632.0 kHz USB 20M
AGA5SC / SCOTT AFB, IL
(14 MAY 1600Z TO 2300Z)
3,308.0 kHz USB 80M
4,872.0 kHz USB 80M
7,545.0 kHz USB 40M
AGA9TR / TRAVIS AFB, CA
4,575.0 kHz USB 80M
7,915.0 kHz USB 40M
14,411.0 kHz USB 20M
COAST GUARD STATIONS:
NMC1 / COAST GUARD ISLAND, ALAMEDA, CA
(14 MAY 1400Z - 15 MAY 0030Z)
7,542.0 kHz USB 40M
15,740.5 kHz USB 20M
22,924.5 kHz USB 15M
NAVY STATIONS:
NIIW / USS MIDWAY CV-41 SAN DIEGO, CA
(14 MAY 1200Z - 15 MAY 0600Z)
4,003.5 kHz USB 80M
7,360.0 kHz USB 40M
14,441.5 kHz USB 20M
NWKJ / USS YORKTOWN CV-10
(14 MAY 1200Z - 15 MAY 0400Z 2015)
4,000.0 kHz USB 80M
7,360.0 kHz USB 40M
14,663.5 kHz USB 20M
20,940.0 kHz USB 15M
NMN / CAMSLANT, CHESAPEAKE VA
7,528.6 kHz USB 40M
14,459.6 kHz USB 20M
19,221.6 kHz USB 17M
NWVC / LST-325 EVANSVILLE, IN
(14 MAY 1200Z-15 MAY 0400Z)
4,007.0 kHz USB/CW 80M
6,913.0 kHz USB/CW 40M
13,974.5 kHz USB/CW 20M
17,500.0 kHz USB/CW 17M
24,782.0 kHz USB/CW 12M
NPAX / US NAVAL ACADEMY MD
4,038.5 kHz USB/CW 80M
7,533.5 kHz USB/CW 40M
14,487.0 kHz USB/CW 20M
17,545,0 kHz USB/CW 17M
20,994.0 kHz USB/CW 15M
PART II. SECRETARY OF DEFENSE MESSAGE TEST VIA DIGITAL MODES. The Secretary of Defense message will be transmitted via Military Standard radio teletype modes described in MIL-STD 188-110A/B and listed below. Reception of Serial PSK will provide a technical challenge to Amateur stations to receive the broadcasts using a high symbol rate Serial PSK waveform not utilized in Amateur radio, but found in all modern military equipment.
Additionally, broadcasts will be sent using Wide Shift FSK (RTTY), as this mode represents a baseline in interoperability common in all radio services. Specific settings are shown below.
MIL-STD 188-110 A/B Serial PSK.
Software to demodulate the military Serial PSK waveform and detailed instructions can be downloaded at:
http://www.n2ckh.com/MARS_ALE_FORUM/Utilizing this mode with soundcard equipment can be challenging and we recommend Amateur stations review the instructions carefully. Receivers should be set for a 2.7 kHz passband between 300 and 3000 Hz. Audio level should be set to just above the minimum level that decodes. Reception of the preamble at the beginning of the transmission is required to demodulate text.
To practice receiving signals in this mode, tune to the following dial frequencies at 1201Z, 1801Z or 0001Z daily.
11,105.0 kHz USB
11,454.0 kHz USB
12,147.0 kHz USB
13,512.5 kHz USB
14,935.0 kHz USB
15,870.0 kHz USB
FSK in accordance with MIL-STD 188-110A/B
Military FSK is Baudot at 850 Hz, 75 baud, low mark, and 2000 Hz center. Most RTTY programs can be set to decode this mode. To achieve low mark while receiving in USB, the reverse shift is selected.
Although not a capability normally found in Military stations, to accommodate amateurs some stations will transmit the Secretary of Defense message using common ham radio modes such as RTTY, PACTOR, AMTOR, PSK-31, MFSK and MT63. Amateur sound card modes will use default settings.
The Secretary of Defense message can be received from the stations listed below.
Frequencies listed are provided as "Window/Dial Frequency" in kHz. All times in Zulu (UTC).
COMBINED BROADCAST STATIONS BY TIME
14 MAY/1400Z MIL STD 188-110 FSK 13,506.0 kHz USB AGA2SY
14 MAY/1410Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB AGA2SY
14 MAY/1420Z MIL STD 188-110 FSK 13,506.0 kHz USB WAR
14 MAY/1420Z MIL STD 188-110 FSK 17,443.0 kHz USB AGA2SY
14 MAY/1430Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB WAR
14 MAY/1430Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB AGA2SY
14 MAY/1440Z MIL STD 188-110 FSK 13,506.0 kHz USB AAC
14 MAY/1440Z MIL STD 188-110 FSK 17,443.0 kHz USB WAR
14 MAY/1450Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB AAC
14 MAY/1450Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB WAR
14 MAY/1500Z MIL STD 188-110 FSK 17,443.0 kHz USB AAC
14 MAY/1510Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB AAZ
14 MAY/1510Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB AAC
14 MAY/1530Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB AAZ
14 MAY/1800Z MIL STD 188-110 FSK 13,506.0 kHz USB AGA2SY
14 MAY/1810Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB AGA2SY
14 MAY/1820Z MIL STD 188-110 FSK 13,506.0 kHz USB WAR
14 MAY/1820Z MIL STD 188-110 FSK 17,443.0 kHz USB AGA2SY
14 MAY/1830Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB WAR
14 MAY/1830Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB AGA2SY
14 MAY/1840Z MIL STD 188-110 FSK 13,506.0 kHz USB AAC
14 MAY/1840Z MIL STD 188-110 FSK 17,443.0 kHz USB WAR
14 MAY/1850Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB AAC
14 MAY/1850Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB WAR
14 MAY/1900Z MIL STD 188-110 FSK 17,443.0 kHz USB AAC
14 MAY/1910Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB AAZ
14 MAY/1910Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB AAC
14 MAY/1930Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB AAZ
14 MAY/1930Z RTTY 7,457.0 kHz USB AGA4AR
14 MAY/1930Z RTTY 7,540.0 kHz USB AGA2SY
14 MAY/1930Z RTTY 7,545.0 kHz USB AGA5SC
14 MAY/1930Z RTTY 7,915.0 kHz USB AGA9TR
14 MAY/2030Z MT63 7,457.0 kHz USB AGA4AR
14 MAY/2030Z MT63 7,540.0 kHz USB AGA2SY
14 MAY/2030Z MT63 7,545.0 kHz USB AGA5SC
14 MAY/2030Z MT63 7,915.0 kHz USB AGA9TR
14 MAY/2100Z MFSK 7,457.0 kHz USB AGA4AR
14 MAY/2100Z MFSK 7,540.0 kHz USB AGA2SY
14 MAY/2100Z MFSK 7,545.0 kHz USB AGA5SC
14 MAY/2100Z MFSK 7,915.0 kHz USB AGA9TR
14 MAY/2130Z RTTY 13,993.0 kHz USB AGA2SY
14 MAY/2130Z RTTY 14,392.5 kHz USB AGA5SC
14 MAY/2130Z RTTY 14,411.0 kHz USB AGA9TR
14 MAY/2130Z RTTY 15,632.0 kHz USB AGA4AR
14 MAY/2200Z MIL STD 188-110 FSK 13,506.0 kHz USB AGA2SY
14 MAY/2200Z MIL STD 188-110 SERIAL PSK 14,487.0 kHz USB ADB
14 MAY/2210Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB AGA2SY
14 MAY/2210Z MIL STD 188-110 SERIAL PSK 20,994.0 kHz USB ADB
14 MAY/2220Z MIL STD 188-110 FSK 13,506.0 kHz USB WAR
14 MAY/2220Z MIL STD 188-110 FSK 17,443.0 kHz USB AGA2SY
14 MAY/2230Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB WAR
14 MAY/2230Z MT63 13,993.0 kHz USB AGA2SY
14 MAY/2230Z MT63 14,392.5 kHz USB AGA5SC
14 MAY/2230Z MT63 14,411.0 kHz USB AGA9TR
14 MAY/2230Z MT63 15,632.0 kHz USB AGA4AR
14 MAY/2230Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB AGA2SY
14 MAY/2240Z MIL STD 188-110 FSK 13,506.0 kHz USB AAC
14 MAY/2240Z MIL STD 188-110 FSK 17,443.0 kHz USB WAR
14 MAY/2250Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB AAC
14 MAY/2250Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB WAR
14 MAY/2300Z MFSK 13,993.0 kHz USB AGA2SY
14 MAY/2300Z MFSK 14,392.5 kHz USB AGA5SC
14 MAY/2300Z MFSK 14,411.0 kHz USB AGA9TR
14 MAY/2300Z MFSK 15,632.0 kHz USB AGA4AR
14 MAY/2300Z MIL STD 188-110 FSK 17,443.0 kHz USB AAC
14 MAY/2310Z MIL STD 188-110 SERIAL PSK 13,506.0 kHz USB AAZ
14 MAY/2310Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB AAC
14 MAY/2330Z MIL STD 188-110 SERIAL PSK 17,443.0 kHz USB AAZ
15 MAY/0240Z RTTY 13,506.0 kHz USB NWKJ
15 MAY/0240Z RTTY 17,443.0 kHz USB NWKJ
15 MAY/0300Z CW-25WPM 4,007.0 kHz USB NWVC
15 MAY/0300Z CW-25WPM 6,913.0 kHz USB NWVC
15 MAY/0310Z AMTOR FEC 13,506.0 kHz USB NWKJ
15 MAY/0310Z AMTOR FEC 17,443.0 kHz USB NWKJ
15 MAY/0340Z MT63 13,506.0 kHz USB NWKJ
15 MAY/0340Z MT63 17,443.0 kHz USB NWKJ
SUBMISSION OF SECRETARY OF DEFENSE TEST MESSAGE ENTRIES.Transcripts of the received text should be submitted "as received". No attempt should be made to correct possible transmission errors. Provide time, frequency and call sign of the military station copied, including name, call sign, and address (including zip code) of individual submitting the entry. Ensure this information is placed on the paper containing the test message. Each year a large number of acceptable entries are received with insufficient information, or necessary information was not attached to the transcriptions and was separated, thereby precluding issuance of a QSL card. Entries must be sent to the appropriate address as follows:
A. Stations copying Secretary of Defense message transmitted from Army and Navy stations, send entries to:
ARMED FORCES DAY CELEBRATION
COMMANDER NETCOM
ATTN: NETC-ITSMD
BLDG 90549 JIM AVENUE
FORT HUACHUCA, AZ 85613-7070
B. Stations copying Secretary of Defense message transmitted from Air Force stations, send entries to:
38 CYRS/CHIEF, AF MARS
203W LOSEY ST, RM 1200
SCOTT AFB, IL 62225
PART III. AUTOMATIC LINK ESTABLISHMENT. Amateur Stations with Automatic Link Establishment (ALE) capability can contact a military station on specific half duplex “cross band” channels established for this purpose. ALE is a selective calling and linking method utilized by government, military, and amateur radio communications.
Military stations will scan and receive certain Amateur HFLINK ALE frequencies, and transmit on the corresponding military ALE frequency. Military stations will also transmit ALE station identification (soundings) on each military frequency at 30 to 90 minute intervals. Amateur stations which are capable may scan the military frequencies and monitor the soundings to build the LQA database or select the channel manually. Amateur stations will call military stations using ALE selective calling on one of the paired cross band channels. HF Radios with an embedded ALE feature, or ham radios with computer-based PC-ALE, are compatible for use with the military 2G-ALE used in this event.
Amateur stations seeking more information about ALE go to
http://hflink.net.
Please note:
Upper Sideband (USB) is utilized on all frequencies for transmit and receive.
Military stations participating in ALE are listed below:
STATION CALLSIGN ALE ADDRESS
AAZ AAZ
AGA2SY 2SYAGA
WAR WAR
ALE FREQUENCY LIST
Channel Amateur Frequency Military Frequency
X75US 3,996.0 USB 4,000.0 USB
X60INT 5,371.5 USB 5,371.5 USB
X40US 7,296.0 USB 7,357.0 USB
X20INT 14,346.0 USB 14,846.0 USB
X17INT 18,117.5 USB 18,272.5 USB
X15INT 21,432.5 USB 20,940.0 USB
X12INT 24,932.0 USB 24,858.5 USB
