I wouldn't worry about the idle voltage being too high for the 811As but I would worry about an 1800 volt capacitor string with 1850 on it. OK, it's only 12.5 volts extra per capacitor - 2.8% high - but it is never recommended to push electrolytics to full voltage.
Neutralisation was recommended back in the 1960s by RCA for a four times 811A amplifier: it was implemented in the UK built KW1000 which was a two tube 572B amplifier. It is done by adding a tertiary winding to cathode choke and coupling via a small HV capacitor to the plate - the KW1000 just used an aluminium plate insulated from ground relatively close to the tubes. It is said that the 30L1, which doesn't have neutralisation, is far more stable on bands above 20m with it: some loads can make it distinctly touchy apparently.
Is it worth going to four tubes? From the viewpoint of more power, as the others say, no. From the consideration of making life easier on the tubes, yes, but if there isn't room or if the cooling is decreased, no. I would suggest you measure the heater voltage of the 811As to start with. There will be some drop in the filament choke, so measure the voltage at the tube socket and at the transformer end of the filament choke. Then check the transformer end of the choke with the amplifier producing full output, and remember that a DVM may then give wild answers because of RF getting in, so use an old fashioned moving coil meter! RCA generally reckoned on +/-10% on filament voltage, but Eimac seemed to go for +/-5%, and that's what I would go for, too. If the filament voltage is too high, then I would suggest a 'buck' transformer, which would also reduce the HV.
