In old days sweep tubes lived a life of a abuse in a TV and they were very rugged and frequently over rated in amps but on the KW1000 is not really overrated because 1000 watts PEP input is about 600 to 650 watts output and with a 320 watts of continuous dissipation that rating is not out of line. Now a AL811 would have to be "rated" at 1000 watts PEP input for 600 watts out but it only has 135 watts of safe continuous dissipation on 3ea 811's. Some use ICAS rating of 195 watts total but that is only a intermittent rating with equal time off with no current (not idle current) for cooling and even using that tubes are way over loaded/taxed. If you do the math you can clearly see which is truly overated and which is not. BTW as I recall the SB200 was rated at 1200 watts PEP input and many of those amps still work today and some with original tubes too. If it was over rated like AL811 series they would have died long ago, had a history of eating tubes and reliability problems too but such is not the case.
The 320 watts for sweep tubes is high but you struck a chord regarding ratings.
There is no ICAS rating for sweep tubes only pseudo CAS. A sweep tube lived in a TV set surrounded by other tubes, stuck in a corner, used as a coat rack, homework depository, moms jungle plants, left on for noise, and no hope of air movement. That's TCAS --- terrible continuous commercial service. A 30 watt sweep tube is simply underrated. The most likely problem with a sweep tube is operator error --- that's not to say incompetence simply a very different tune up procedure. The plate current on a pair of 6KD6's will easily soar to well over 1000ma when the plate is tuned off resonance. That's what provoked the builders to add the 200 watt for 40 second rating to the data sheets and no, it's not once for the life of the tube. Sylvania built 6KD6's under special contract for the SR-400A. They were balanced, worked in the second bias quadrant limiting them to 500 watts in and 275 out in AB1 SSB mode. Hal originally thought it would be fine without a blower but quickly added one.
Sweep tubes are not those wimpy things, just misunderstood.
