Could someone explain how having a reactance from grid to ground - which at some presumably lower frequency is capacitive and at higher frequencies is going to be inductive - provides negative feedback?
As in providing the equations?
I am aware that W8JI is more than dubious on this matter, and although I don't always agree with Tom, I do feel that he has an exceedlingly strong point here.
If your referring to this comment: Collins used 200pf grid caps to ground in the 30L1 and others followed. That cap changed the inductive lead to capacitive throughout the ham bands and added 3db to 6db of negative feedback for linearity. Removing them because a wayward tube shorting damages them is questionable.
The inductance of the grid lead in an 811 is 40 to 50nH and combined with the 200pf cap are series resonant to ground at approximately 45Mc. Below 45Mc the series pair behave as a capacitor to ground not inductor. There is a bridge composed of the plate to grid 5pf and 200pf to ground that provides 1/40 ratio of Negative feedback. The center of the bridge is attached to the grid and 200pf capacitor to ground. The negative feedback from the 5pf capacitor is injected at junction of the grid and 200pf cap.
Solves a few problems, the grid lead to ground is capacitive throughout the ham bands not inductive, adds negative feedback, and reduces the gain.
W8JI does not have a strong case or any case at all. He concocted a theory that the Collins 30S1 and 30L1 designed by Bruene and Senti generated negative feedback using a bridge composed of the cathode to grid capacity and 200pf grid to ground --- which is absurd. This bizarre theory has been passed around for the last 40 years to discredit Orr and Senti both superb engineers.
The facts: The 30S1 negative feedback is generated by a bridge made up of a 5pf capacitor connected from the plate to CG through a parasitic suppressor.
This is connected around the screen. The lower leg is a 200pf capacitor to ground. This is a 1/40 ratio of negative feedback. It also prevents any parasitics at
the plate reaching the CG. An eloquent design. W8JI simply didn't see or wouldn't acknowledge the 5pf capacitor connected around the screen to the control grid. He apparently assumed the screen would prevent any plate feedback because the screen would block it. With this in mind an alternate reality bridge was developed. The Cathode to grid and grid to ground. Hence decades of a false narrative.
The 30L1 has 5pf plate to grid, a perfect fit for the same ratio using 200pf capacitors. The added value is the grid to ground profile becomes capacitive not inductive throughout the ham bands. The reduced gain also reduces the need for neutralization.
Would I neutralize a GG amp --- of course. Would I use the standard inductor wrapped around the input technique --- no because if it is neutralized at 29Mc it will become progressively under neutralized as you move to 3.5Mc because of the effect the inductance of the transformer has on capacitive reactance. Ok, so what. This is why the IMD and linearity of the lower bands progressively become worse using that method.
All of this and legions more are available in (Single Sideband Principals and Circuits. Pappenfus, Bruene, and Schoenike), The Collins archives design letters, many QST articles written by Bruene, and just a bit of common sense.
Regards Jim
