Author Topic: KW 1000 LINEAR AMPLIFIER  (Read 8996 times)
1B1AB
« on: June 27, 2007, 04:22:36 PM »
My KW 1000 Linear amplifier makes my TS 440s Kenwood transciver deaf I lose about 5/6 s point
on reception any idea? 73's  de  1b1ab
AD5X
« Reply #1 on: June 27, 2007, 05:40:15 PM »
Sounds like the T/R relay in the amp needs to have the relay contacts cleaned or adjusted, or the relay should be replaced.
Phil - AD5X
KE3WD
« Reply #2 on: June 27, 2007, 08:09:57 PM »
I'm with Phil, relay is first suspect.
Relay contacts can be cleaned with ordinary white paper or a clay containing rough business card.
Put the paper between the contacts and polish them.
Don't use anything more abrasive than that on them.
1B1AB
« Reply #3 on: June 30, 2007, 11:41:05 AM »
Hello guys.
Thanks  for  information one hundred  percent  you  are  right  I  only  clean  the  relay  and  become  like  new  now  receive  fine  thanks  again.
73’s  de  1b1ab  Soyer  from  North Cyprus
