Hello,
I have an Icom IC-7610 and have installed the RS-BA1 software. The rig works remotely; RX and TX (both SSB and CW) work as advertised. The CW macros work great.
However, I cannot get the SSB transmit macros working. They play the just fine (via the RS-BA1 macro button), and I can hear the audio, but they will not transmit. I get no output power when I play them. I have the "PLAY only" box unchecked. The LEVEL is at 12 o'clock. The power level from the rig is at 100w, so it's not that.
Anyone here have any ideas how to get those macros to transmit? I'm assuming there is a setting I am missing.
I'm also guessing the settings will be the same for the IC-7300, so if someone has them working on that rig, please share what you did.
Thank you!
Scott - WX0V
