Nothing worth pursuing from the nothing I am hearing on phone. Same on 12 and 10. Can't speak about digital and CW.
See, that is the thing about listening on phone. You only have a tiny slice in the frequency domain, and a tiny slice in the time domain. Even if you happen to be there at the right time (openings often only last seconds to minutes) and even if you have a panadaptor to see more of the frequency domain, the chances of you acquiring and working anyone are slim in these sunspot levels. You need big nice sustained openings with much stronger signals.
You suffer from none of those problems with FT8. You know EXACTLY what frequency the DX will appear on as you listen to the entire bandwidth where everyone appears. And you have visual confirmation of the DX callsign, its signal strength and physical location (grid square). AND if you run JTalert, you have a captured record of all of this information and when it happened AND are they on LOTW or Eqsl or not. Even if you are out when the DX appears, you will still know when they did appear and can try again the next day of conditions are similiar.
Yes it is hit or miss, but you can get an idea of what you missed, when, and try to develop a strategy to get them. Plus if you are in the house, you can turn up the volume and run back to the shack to get set up on the DX and maybe snag them the first time. Yeah, it ain't guaranteed, and contrary to popular belief it is NOT like shooting fish in a barrel, but you have a somewhat better chance than waiting on 50.125 for a phone signal. Not to mention the 20dB advantage over SSB.
Yeah 20db. At least. So the difference between 100 watts and 10,000 watts. Think about that. Your little peanut whistle 100 watt station on SSB will perform like a 10,000 watt station on FT8. This is only one of the reasons "modest" stations are flocking to the FT8 bandwagon in droves.
If you have no interest in chasing DX and prefer one on one ragchews, real conversations, about some topic other than signal reports and where you are, then FT8 is NOT for you. But typical "QSO's" with true DX stations are typically ur 59(9) and thank you anyway on any mode including SSB.
So, to sum up. Plenty of DX on the upper bands, but only for people willing to change with the times and make a very very small investment in equipment and an investment in time and learning. And if you have no interest in working DX to begin with, then no problem, wait until the "spots" come back.
