See, this is where you keep loosing me...RF and I-Gate functionality don't quite work like you're describing...because you're not accounting that you won't see duplicates in the APRS-IS logs.
First, KNAPPA's not a callsign, it's a weather station...Next, why do you keep referring to the IGate, then referring to the RF???
Your stations won't do both, as that would be a duplicate packet. You need to look at the APRS log for the server you're connected to in order to determine if your login is sending duplicate packets to APRS2's server. At this time, you're 2 calls listed above are not connected to northwest.aprs2.net. I can tell you, though, that your NA7Q- 9 node is sending to APRS-IS - out of 52741 packets received, 40709 duplicates, with 0 erroneous packets dropped. You're racing milliseconds of time between the packet queuing a digipeater, or reaching the APRS-IS server...only one will be recorded in the APRS-IS, the other IS A DUPLICATE!
I had the same issues when I first setup to and APRS-IS server...now I can now tell if there's a connection issue on the Internet between myself and the server I chose. REMEMBER, YOUR PREFERENCE SHOULD BE FOR THE PACKET TO BE HEARD ON AIR, NOT ON THE INTERNET.
But, I did find NA7Q-2 connected to T2CAWEST...guess what??? Of 2614 packets received, 2226 are duplicates and 18 were erroneous packets dropped. And I found KNAPPA connected to T2INDIANA...of 575 packets received, 435 were duplicates and 0 erroneous packets dropped.
So again, I ask, are you sure they're being rejected???
I know duplicates from different stations won't be shown, aka, if a station is heard by two igates, it won't show up as being received by both, because it's a duplicate, only by one. I know this and this isn't my issue.
RF and IGate do work exactly as I described. Maybe you misunderstood what I meant.
First off, KNAPPA is a call sign, it's a tactical type call. It is a weather station, digipeater, and an igate.
Why do I refer to igate and then RF? Because the stations send RF beacons, and are picked up and igated by other stations. Or should be, if they are not duplicates, errors, or whatever.
My two stations are not connected to northwest.aprs2.net because the server won't gate my other stations when they beacon. It rejects them.
Despite your operation, the packet is to be heard ON THE AIR AND THEN gated to the internet. That's the whole purpose of an igate. Receive and then send to the internet, and vise versa in cases.
