Author Topic: KI4MQF-10  (Read 3425 times)
KE4IAJ
KI4MQF-10
« on: March 19, 2018, 08:33:29 AM »
Can someone take a look at this station's info and tell me if I set it up properly as a Digipeater and IGate?
I am using UI-View32 connected to a Kantronics KAM Plus and I used this tutorial http://www.wb2lua.com/papers/IGate.pdf but I used the URL http://wa8lmf.net/miscinfo/APRServe2.txt to download the servers. I selected main.aprs2.net, midwest.aprs2.net, and northwest.aprs2.net.
It shows up on the map but I'm not sure if it's setup correctly or not. Any help would be appreciated. Thank you.
KB3VWG
RE: KI4MQF-10
« Reply #1 on: March 19, 2018, 09:01:40 AM »
https://aprs.fi/info/a/KI4MQF-10
If you're IGating, there would be a section called "Stations heard directly by KI4MQF-10"
If you're digipeating, others should begin to have a path through you...but you don't seem to be reporting anyone as being heard.
Also, see the packets logged to the APRS=IS: https://aprs.fi/?c=raw&call=KI4MQF-10
KB3VWG
