I have a Windom antenna up about 40 feet. I'm seeing noise on my S meter that is running at S9 or higher on 40 and 80 meters. Nothing on 10, 15. Some on 20.
Is this normal, or is there some piece of equipment hashing my reception?
Thanks
N1AUP
Not normal where I live. Especially on 40, typically s1 or 2 without any preamps. I assume you are not running preamps. 80 might be S5 at times. Depending on static crashed that might be propagated into my area. Of course If I have static crashes in my area I am at S0 because the radios will be turned off
Start by getting the radio on battery power. Then turn off the main breaker to your own house. Note the noise. If it drops significanty, the turn back on the main breaker, does it come back? Then start flipping breakers one at a time. find the room or service that causes the noise, then start unplugging things one at a time.
If the problem is not in your house, uh oh...
