Hi
You have found out that there is a cause of interference in your house.
Try to find that first.
Then the common mode chokes, it is wrong to think that a common mode choke of an FT240-31 with as many RG6 windings as possible will be perfect on 80 and 40.
For the right common mode choke look at G3TXQ site:
http://www.karinya.net/g3txq/chokes/It can be a great help good common mode chokes, it might help nothing at all.
If the noise is picked up by your antenna, the choke will not help.
I have build HalfWave End Fed antennas that didn't have any issue with common modes, they had ofcourse a good common mode choke.
And i have had balanced loops that did have terrible noise problems, the situation is very depending on your local surcomstances and way of placement of the antenna.
73 Jos
