Author Topic: Linking two EFHW-8010 end fed wire antennas  (Read 1611 times)
N8OXQ
« on: February 19, 2019, 04:04:12 PM »
Brand new General with an end fed wire question. I am going to mount two EFHW-8010 antennas on my 40 ft tower. They will be 40 at the tower slopping to 10 ft at the end of the 130 ft. One will run N-S and the other E-W. Now the question(s). Would there be any advantage to linking the two and will it work? If it will work do they make or can I make a remote coax switch that will have three options. 1. Link the two together. 2. Only N-S antenna. 3. Only E-W antenna. Just letting my mind explore the outer rim of the known universe.     Thanks
RE: Linking two EFHW-8010 end fed wire antennas
« Reply #1 on: February 21, 2019, 11:54:19 AM »
You have to be incredibly lucky or do some clever engineering to connect two antennas together like that to get omnidirectional coverage, so I wouldn't bother with linking the two together.
A turnstile is an example of combining two antennas together for an omni pattern.
