Author Topic: 20 Meter Prop Question  (Read 1664 times)
KM4DYX
« on: July 29, 2019, 06:38:55 AM »
My QTH is about 470 miles from the NCDXF beacon 4U1UN. I would think that a station at that distance would be difficult to copy on 20 given current condx and the take off angle involved. The VOACAP prediction program gives it a 0% probability at this moment (1330 UTC). Yet, the beacon is strong and I can even copy the 100 mw dash.
This is not a new or rare instance. I can usually copy the NY beacon most of the day. Anyone care to comment?
Al
RE: 20 Meter Prop Question
« Reply #1 on: July 29, 2019, 06:57:21 AM »
Well, it is Es season.  And there are E clouds nearly every day up in your part of the world.  Perhaps this might explain it. See if you still copy it in a month when the E clouds disappear.
OZ8AGB
« Reply #2 on: July 29, 2019, 07:06:09 AM »
Sunday 10m and 12m was open here in the EU in the late afternoon. Lots of FT8 and CW activity.
WA4DOU
« Reply #3 on: August 01, 2019, 01:07:57 PM »
Propagation programs, including VOACAP aren't capable of 100% accuracy at any time in the year and should only be regarded as predicting fairly accurate trends. Frequent operation on a single band only, will give you far more insight into it than any propagation program.
OZ8AGB
« Reply #4 on: August 02, 2019, 02:01:57 AM »
Turn on the radio on the band of interest and:
1) Call CQ on CW and check Reverse Beacon Network
or
2) Call CQ on a Digital mode and check Psk reporter
« Reply #5 on: August 02, 2019, 08:21:56 AM »
Exactly.
« Reply #6 on: August 02, 2019, 08:22:19 AM »
or
This.  ^^
KM4DYX
« Reply #7 on: August 02, 2019, 10:41:50 AM »
Thanks all. I've used PSK Reporter and RB quite a lot and also WSPR. My interest was in the actual mode of propagation over this particular path. E-layer sky wave would seem to be the most likely, but I seem to recall hearing this beacon last winter as well.
Re: 20 Meter Prop Question
« Reply #8 on: December 17, 2019, 10:30:22 PM »
There is a winter Es season as well.  Often centered around Christmas to New Years.
73 John W5TD
N9FB
« Reply #9 on: December 18, 2019, 04:12:55 AM »
isn't E skip primarily 10 meters and above?  i am trying to understand the dynamics of working stations outside ground wave distance but in the 100 - 400 mile range on 20 meters in order to potentially obtain 20m WAS and states like OH are proving difficult from central Indiana (on 20m).
I did work a station just 130 miles away in KY on SSB this year on 20m, copy was very weak but confirmable.
any insights into what conditions make short distance contacts outside ground wave possible will be appreciated
« Reply #10 on: December 23, 2019, 04:17:13 PM »
Plenty of Es on 20 meter too.
