Author Topic: Perth Plus Antenna restoration  (Read 377 times)
KA0SBL
« on: October 20, 2019, 07:41:08 PM »
I have a Perth Plus antenna in good working order, but the often found surface cracks. I'm thinking about a little JB weld for the larger cracks, a fine sanding & cleaning/surface prep followed by a few coats of black spray paint. Or possibly plasti-dip, just not sure how that will hold up in the long run exposed to the sun and elements.
Thoughts, ideas or experiences?
-Ken
SP9HZX
Re: Perth Plus Antenna restoration
« Reply #1 on: October 09, 2022, 04:16:30 AM »
I have applied this one http://www.plastidip.pl/
Now my 24 years old Outbacker looks great
KG4RUL
« Reply #2 on: October 09, 2022, 04:40:42 AM »
I may be wrong on this but, I believe JB Weld is an epoxy with finely dispersed metal particles in it.  Could that present a problem when used on an antenna?
SP9HZX
« Reply #3 on: October 09, 2022, 04:42:57 AM »
No at all.
It works perfect.
KB1GMX
« Reply #4 on: October 09, 2022, 08:25:39 AM »
JBweld epoxy is availabe with metal fill and without.
The metal filled version could affect the antenna if enough
was used but a few small spots not likely an issue.  I would
not use epoxy there because you really want flexibility.
the plastidip sounds good, with black spray paint.
Last time I encountered something like that I got a long
piece of glue filled (two layer) heat shrink. It flexes!
Covered the whole length.  Worked fine so far (7 years).
Alison
