Author Topic: MFJ 704  (Read 328 times)
AA3R
MFJ 704
« on: November 11, 2019, 11:30:00 AM »
Basically, how would you connect this unit between an Ameritron 811 and an Icom 7300...I know it's not needed but still, I like to be extra safe.
Re: MFJ 704
« Reply #1 on: November 11, 2019, 12:05:23 PM »
Are you looking for comments or do you have a Question?
My question is - why buy it if you don’t need it? It’s a simple matter to determine if it serves any purpose.
AA3R
Re: MFJ 704
« Reply #2 on: November 11, 2019, 12:55:16 PM »
It's a question, I actually got one for free
Re: MFJ 704
« Reply #3 on: November 11, 2019, 12:56:59 PM »
In that case dont use it, something less to break
AA3R
Re: MFJ 704
« Reply #4 on: November 11, 2019, 01:02:38 PM »
Which brings to the question: How do you hook it up?
I have scoured the web to mo avail...sent MFJ a msg that has not been answered
Re: MFJ 704
« Reply #5 on: November 11, 2019, 01:07:04 PM »
There is a goesinto and a goesoutta, doesnt matter which.
https://www.mfjenterprises.com/support.php?productid=MFJ-704
Re: MFJ 704
« Reply #6 on: November 11, 2019, 01:29:29 PM »
You might try re-“scouring”  for MFJ 704 instruction manual. It’s widely available on a number of web sites as a downloadable PDF.
Hint - Between output and antenna
W0CKI
Re: MFJ 704
« Reply #7 on: November 11, 2019, 01:33:49 PM »
Easy to find and easy to use between amp and antenna. If you don't need it don't use it.
73 Gary W0CKI
AE0Q
    • AE0Q Amateur Radio
Re: MFJ 704
« Reply #8 on: November 11, 2019, 01:54:42 PM »
Basically, how would you connect this unit between an Ameritron 811 and an Icom 7300...I know it's not needed but still, I like to be extra safe. 73
If the original poster thinks this goes between radio and amp, then I would suspect maybe it is the ARB-704 amp keying interface, not a low pass filter??
NSGA Edzell 1974-77  CTM2  GM5BKC : NSGA Rota 1972-74   ZB2WZ, SV0WY
https://radioandtravels.blogspot.com/
http://www.qsl.net/ae0q/
AA3R
Re: MFJ 704
« Reply #9 on: November 11, 2019, 02:11:06 PM »
Sorry, it's the ARB 704 :-\....I found said instructions
Re: MFJ 704
« Reply #10 on: November 11, 2019, 04:37:50 PM »
Now he tells us.
Toss it as they have reliability problems and are certainly not needed for that amp anyway.
W0CKI
Re: MFJ 704
« Reply #11 on: November 11, 2019, 04:43:02 PM »
Not needed and not very good, lose it.
Gary W0CKI :-*
Re: MFJ 704
« Reply #12 on: November 11, 2019, 05:04:26 PM »
As a new AL811H owner and the owner of two IC-7300's, I can assure you that you don't need or want a keyline interface for these amps/radios.
N4MU
Re: MFJ 704
« Reply #13 on: November 18, 2019, 08:19:22 AM »
Couple years ago when I was just setting up at my current QTH I bought one to use between xcvr and my ALS-600. After a few days...and some frustration I removed it and returned it to the vendor with a, "Why in H did I buy this useless thing"? I'm sure there are some circumstances where it might be desirable but I certainly didn't...still don't... need it. Consider: It was free. That should have told you something. ;)
