Author Topic: Replace rubber PTT switch cover on Kenwood TH-G71A?  (Read 51 times)
KC0YKN
« on: November 16, 2019, 09:10:56 PM »
I picked up a used Kenwood TH-G71A HT at a hamfest today.  The price was good, until I looked closer and discovered the rubber PTT switch cover was gone.  It was in a baggie in a silent auction.  I should have looked closer!
I couldn't find a replacement switch cover on the Kenwood parts web site when searching by model number.   Can anyone suggest a suitable substitute I might be able to install on the radio?
Thanks for any help you can offer.
Dennis - KC0YKN
WD9EWK
    • WD9EWK/VA7EWK
Re: Replace rubber PTT switch cover on Kenwood TH-G71A?
« Reply #1 on: November 16, 2019, 10:10:49 PM »
PacParts, which handles parts for Kenwood products, lists a "Button, PTT" that looks like the covers for the buttons on the side of the radio, including the PTT. Unfortunately, that is listed as a discontinued part. You can see the parts PacParts has for that radio at:
https://www.pacparts.com/model.cfm?model_id=THG71A&mfg=Kenwood&back=0&action=list_part
73!
Patrick WD9EWK/VA7EWK
http://www.wd9ewk.net/ - Twitter: @WD9EWK or http://twitter.com/WD9EWK
KC0YKN
« Reply #2 on: November 16, 2019, 10:17:50 PM »
Patrick,
Thank you.  That certainly looks like the right item.  I'm not surpised it's discontinued.  I wonder if any other radio model uses a button which is alike enough to use as a substitute.  I suspect there isn't one, and if not, I'm not out a lot of money.  The radio came with an aftermarket speaker mike, so I can probably tape over the hole in the side of the radio and just use the speaker mike.
Thanks again for your time.
Dennis - KC0YKN
WD9EWK
    • WD9EWK/VA7EWK
« Reply #3 on: November 19, 2019, 01:16:33 PM »
Patrick,
Around the same time the TH-G71A came out, Kenwood also released the TH-D7. The TH-D7 used the same battery packs and many other accessories as the TH-G71, but I think the buttons on the left side of the radio are different. PacParts has that assembly for the TH-D7, "Button Assembly (PTT/Lamp/Moni)":
https://www.pacparts.com/model.cfm?mfg=Kenwood&model_id=THD7A&row_start=1&src_model_id=TH-D7&action=list_part
The lamp and MONI buttons are angled on the TH-D7, where they aren't on the TH-G71.
73!
