Author Topic: CPO for bug type practice  (Read 193 times)
K7MPZ
« on: December 10, 2019, 01:12:20 PM »
Can't seem to find anything but straight key oscillators. Would like to practice paddle type keying.  Any leads?
Dale
Dale Fiorillo
Sequim, Wa
K7MPZ
K4EQ
Re: CPO for bug type practice
« Reply #1 on: December 10, 2019, 01:48:12 PM »
That's all you need if you want to practice with a bug (semi-auto key).
KI7RS
« Reply #2 on: December 10, 2019, 01:50:33 PM »
https://qrpguys.com/qrpguys-code-trainer
This one does both iambic and straight key, and auto detects what's plug in when you turn it on.  I have to hold down the dah part of my bug when I power it, so it detects it as a straight key instead of a paddle.
K7MPZ
« Reply #3 on: December 10, 2019, 03:38:21 PM »
Confused, still, so simply put, if I push paddle right I will get dits, and if I push left I will get dahs? The schematic would indicate this, but I don't know the logic of the chip. I use a vibrokeyer for paddle mode.
Dale
Dale Fiorillo
Sequim, Wa
K7MPZ
W6MK
« Reply #4 on: December 10, 2019, 04:23:12 PM »
Your confusion is with terminology. A CPO is a code practice oscillator. I makes a tone when the circuit is closed. With a paddle and a CPO you need an electronic keyer in between to generate dits and dahs when you use the paddle.
« Reply #5 on: December 10, 2019, 07:32:19 PM »
There is the MFJ-401E for $95. https://www.mfjenterprises.com/Product.php?productid=MFJ-401E
And you can find keyers on Ebay.
« Reply #6 on: December 10, 2019, 08:14:09 PM »
I heartily endorse the K1EL kits.  Great price, good feature set, easy to use.
W4CDO
« Reply #7 on: December 14, 2019, 06:57:15 PM »
I use my Icom 756ProIII for code practise, without transmitting a signal. Just go to CW mode and turn break-in off. You will hear the sidetone. Other Icom radios work the same way. I don't know about the other brands, but I suspect that they can do this too.
Another option is to connect to a dummy load and reduce power to minimum.
Jerry W4CDO
« Last Edit: December 14, 2019, 07:05:34 PM by W4CDO »
K7MPZ
« Reply #8 on: December 14, 2019, 07:56:03 PM »
I ordered the qrp guys trainer, the K1el model was out of stock.  My rig has
a practice mode, but it is waaay to big for lugging around, and even 1st class airplane seats don't have power for a yaesu dx3000!
Dale Fiorillo
Sequim, Wa
K7MPZ
