Welcome to AllStarLink!
AllStarLink is a network of Amateur Radio repeaters, remote base stations and hot spots accessible to each other via Voice over Internet Protocol. AllStarLink runs on a dedicated computer (including the Rasperry Pi) that you host at your home, radio site or computer center. It is based on the open source Asterisk PBX running our app_rpt application. App_rpt makes Asterisk a powerful system capable of controlling one or more radios. It provides linking of these radio "nodes" to other systems of similar construction anywhere in the world via VoIP.
AllStarLink's primary use is as a dedicated computer node wired to your repeater or radio. Connections from Echolink, other VoIP clients and telephone calls are supported. We also have a Java Applet which can be used on older computers to access AllStarLink nodes.
AllStarLink has 18,254 users and 14,185 nodes.
the allstarlink page has just been updated
for a full list of the the allstarlink nodes all over the world see
http://stats.allstarlink.org/world map of allstarlink
http://stats.allstarlink.org/maps/allstarUSAMap.htmlyou can make contacts on allstarlink using the windows webtransceiver which works using java
it works on the palemoon browser
https://www.palemoon.org/you can also dial in to the allstarlink system using the telephone network
