Well, it turns out that mine are the 28V bulbs. Was able to tell by the fact that the zener diode that regulated the voltage down to 12 was not present on my board - outline was there, but no diode. Instead of ordering the bulbs, I put a couple of frosted bright white LEDs in place of the bulbs with a 5.6K resistor in series. About the same brightness level as the bulbs, but won't have to worry about replacing one again. My manual shows two part numbers for the bulbs - probably one for 12V and one for 28V.
Not sure how difficult it is to replace the blower in your amp. I replaced one in my Alpha 86 years ago - probably about the same chassis layout. I recall that was not fun.
73, K8AC
