I really appreciate the input. For perspective, I was first licensed in '67 but let the license lapse in the late 80's due to CC&R restrictions. Several months ago I restored my license & call. I share this because in the early days I had beams, and often worked off a huge log periodic antenna, so I was a bit spoiled.
Now to the topic at hand. The MFJ-1795, with their ground plate, should function without radials. An alternative, though taller, would be a 4-BTV with a laydown mount, also at ground level. It would be near a couple of palm trees, so likely wouldn't draw attention.
Two quick questions, and thanks in advance for sharing your insights:
1). Which of these, in your experiences, would perform better. ( I can live within the confines of what I can do since it's better than nothing ).
2). Considering I'm using a Yaesu FT-991A, would I be better to invest in an antenna analyzer and just tune both for optimum performance, or getting an external auto antenna tuner ? The 991A has an internal tuner.
Again, thanks so much for sharing.
