Author Topic: BATTERY PACK FOR YAESU FT70  (Read 126 times)
K7MPZ
« on: March 25, 2020, 01:25:41 PM »
     I really need to power the radio from aa cells while in the field for long times, and there
will be no recharging facilities.  Yaesu only seems to sell the lithium-ion packs.  Has anyone modded
a case, or accessed  the external dc in with a homemade battery pack? I keep looking at the a/c
charger that uses 10.5vdc to supply 8.4vdc for charging.
« Last Edit: March 25, 2020, 01:29:46 PM by K7MPZ »
Dale Fiorillo
Sequim, Wa
K7MPZ
LA9XNA
Re: BATTERY PACK FOR YAESU FT70
« Reply #1 on: March 25, 2020, 02:32:19 PM »
You can build a voltage regulator circuit with a lowdrop voltage regulator chip.
There are several circuits avalable on the internet.
Basical the circuit consist of the voltage regulator and a few capacitors.
https://circuitdigest.com/electronic-circuits/high-voltage-low-dropout-voltage-regulator-circuit-using-mic29302
http://www.ti.com/lit/ml/slyy151a/slyy151a.pdf
K7MPZ
« Reply #2 on: March 25, 2020, 03:17:16 PM »
Wow, thanks, good stuff. This should be what I need.
Dale Fiorillo
Sequim, Wa
K7MPZ
