Author Topic: Vectronics HF-600 (AEA LA-30) antenna switch  (Read 110 times)
VE1CSM
« on: April 13, 2020, 12:30:17 PM »
Does anyone have the make and part number for the antenna relay used in the Vectronics HF-600 (AEA LA-30) amplifier. Or a suggestion as to what i could use. Looks like someone has installed a regular Allen-Bradley DPDT relay in the unit i have here. Thanks in advance, Colin...
W1QJ
Re: Vectronics HF-600 (AEA LA-30) antenna switch
« Reply #1 on: April 13, 2020, 12:36:42 PM »
Generic relays work just fineYou don’t need an exact replacement.  Is the one on there not working?
« Reply #2 on: April 13, 2020, 12:39:43 PM »
Both of those amps have reached collector status. As I remember it is a generic 12VDC relay.
VE1CSM
« Reply #3 on: April 13, 2020, 01:39:16 PM »
It works but input to amp shows higher than ideal SWR, 2.5:1 on all bands and had burned contacts before on cw using QSK.
