Hello,
Guys, I am in great need of assistance to be able to reprogram this radio using software. I have the proper cable the PG-4W that I use to be able to program with and do APRS years ago. I would love to be able to properly reprogram this radio and put it back into service, doing the whole thing without a computer is more than I want to tackle as I have a lot I want to put into the radio for use.
Since I can not find a older computer with a serial db-9 port this is what I have undertaken so far.
I bought usb to db-9 serial cable. I installed the drivers and they were to new, so I back dated the Prolific drivers to version 3.2.0.
I checked the ports under Device Manager in Windows 7 and it shows no errors. However I am not sure of the port communication settings that may be required such as baud rate, flow control,etc. I have worked with differnent settings, no combination of settings has worked.
I am also unsure what if any steps need to be setup in the radio for it to receive information.
I am seeking assistnace with both port settings and setting the radio to recieve data. I have researched and worked on this without luck.
Also if you know of something I have not thought of I am open to your ideas.
Thanks in advance for your kind assistance and time to help me with this issue.
James
de W0PPD
