Author Topic: 2 meter 1/4 wave ground plane....radials vs radiator question....  (Read 136 times)
KO4BRD
I'm back with another silly question for the group that I hope someone can help with.  I am going to build a 2 meter 1/4 wave ground plane antenna. I have some 3/16" diameter copper tubing handy that I can use. This tubing would be perfect for perfect for the radials, but difficult to solder to the center pin of my SO-259 connector. My question is this - are their any issues if the radials are made from 3/16" hollow copper tubing and the vertical radiator is a solid copper (#8 wire)? Not sure how this would affect performance or SWR. Any info is appreciated. Thanks!
KO4BRD
KS2G
Re: 2 meter 1/4 wave ground plane....radials vs radiator question....
« Reply #1 on: June 10, 2020, 01:39:43 PM »
KO4BRD
Why did you post this in the Licensing forum?
You're more likely to get the information you desire by posting your question in the: Antennas, Towers and more forum
KX0Z
« Reply #2 on: June 11, 2020, 01:09:11 AM »
Tubing should be very easy to solder.  Tin the pin and the inside of the tubing before you solder it together.  Once both are tinned the solder should easily wick/flow into the tubing and onto the pin.
W9WQA
« Reply #3 on: June 11, 2020, 10:54:43 AM »
and it dont matter
