Michael (N6MST):
Glenn is correct and is a very competent engineer and ham. I've never known him to mislead anyone on the forums or claim technical supremacy at the expense of someone else (as some do). He does have an obsession with spelling and capitalization though.
Regarding grounding and bonding... This is more of a religious topic on the forums and I hesitate to start another humorous dispute on the issue. Needless to say, Angelo's (KD2HPQ) suggestion to pick up the ARRL handbook on bonding and grounding is a good one.
With regard to your situation, a primary goal should be to "keep RF out of the shack", so that it does not interfere with computer interfaces, analog (mic) interfaces, radio operation, etc. Generally, an RF choke or Balun (both common terms for the same thing, just as Glenn mentioned) on the coax before entrance to your home and operating area OR a coax grounding block attached directly to a solid grounding rod system, just before entrance to your home, will help control this.
In the latter case, you will have established an alternate ground path (other than the AC plug SAFETY ground) for your radio, via the coax shield, to EARTH ground, which under some circumstances can lead to small currents (noise) through the radio from the house safety ground. The best way to handle this is to have a dedicated power/ground line run directly from your entrance panel to the shack, and then use a ground bar as a single-point ground for all equipment in the shack, with the power panel ground and shack ground tied together per code OUTSIDE your home. The "ground loop" this creates is short and folds back on itself without any external noise-makers in the circuit, hence works well. This is more complex and expensive than a Balun and is what CAN be used in a high man-made noise (inverter driven ashers, A/C, solar installs, etc.) - it's what I do at QTH#1 and has solved all sorts or noise and RF problems.
But a Choke/Balun is a good solution, too, and creates no complex grounding issues to think through. I use this approach as a 2nd QTH.
So - reading the ARRL grounding and bonding book is very worthwhile. Note that in a grounding system, high frequency components will see higher impedances, causing the EARTH ground part of the function to work poorly, very rapidly as frequency rises and distance to "EARTH" grows. For that reason, your shack ground should be viewed mainly as a LOCAL ground reference at RF and as a noise free safety ground at AC. AC noise, even low frequency noise, can be so large on some home safety grounds that it will generate higher frequency products in your radio and even by a process called PIMs, within the house wiring. Inverter driven appliances and solar installations are both chief drivers of this noise.
That said, get the book, read it, think about it and then develop your own concept for a station ground. If you really need it. A balun works well.
Best Regards,
Brian - K6BRN
