Author Topic: How to get adif2cabr.exe to not barf on my adif file  (Read 82 times)
WA2ISE
« on: June 20, 2020, 12:01:01 PM »
The program adif2cabr.exe keeps barfing up <EOH> not found (whatever that is) when I try to convert my adif file to a Cabrillo file, so I can submit a log to the June VHF contest.
How do I fix my adif file?  This file comes from the WSJT-X program I use to do FT8.
KG4RUL
Re: How to get adif2cabr.exe to not barf on my adif file
« Reply #1 on: June 20, 2020, 12:40:44 PM »
The ADIF format requires an end-of-header <EOH> tag at the end of the header.  Apparently the program generating your ADIF file is not including this.
K4BNC
« Reply #2 on: June 20, 2020, 01:26:14 PM »
Doesn't WSJT-X generate a Cabrillo file itself?  I think you have to have turned on the contest mode.
WA2ISE
« Reply #3 on: June 20, 2020, 01:27:58 PM »
Looked at my adif file with notepad, seems there is no header.  LOTW doesn't seem to mind this.   ???
